line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
do
echo $b
# echo $g
-i $b
done
* include/bsp.h: Remove unnecessary boilerplate comments.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac, gdb-init,
preinstall.am, clock/clock.c, console/console.c, include/bsp.h,
include/bspopts.h.in, include/coverhd.h, include/tm27.h,
network/network.c, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/cfinit.c, startup/init5329.c,
startup/linkcmds, startup/linkcmdsflash, timer/timer.c: New files.
