Update #3285.
Updates #3520.
Update #2408.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
* Makefile.am, startup/linkcmds, startup/linkcmdsflash,
startup/linkcmdsram: Use top level shared bsp_get_work_area()
implementation.
* Makefile.am, configure.ac, startup/bspstart.c, startup/linkcmds,
startup/linkcmdsflash, startup/linkcmdsram: Add use of
bsp_get_work_area() in its own file and rely on BSP Framework to
perform more initialization. Remove unnecessary includes of
rtems/libio.h and rtems/libcsupport.h.
* startup/linkcmds, startup/linkcmdsflash, startup/linkcmdsram: Add
wildcard to gcc_except_table section so programs compiled with gcc
4.3.x can link.
* include/coverhd.h, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/linkcmds, startup/linkcmdsflash,
startup/linkcmdsram: Correct license URL and/or fix mistake in
copyright notice. Both of these mistakes appear to be from code
submitted after these changes were made previously.
* Makefile.am, README, startup/init5235.c, startup/linkcmds,
startup/linkcmdsflash, startup/linkcmdsram: Modify to the mcf5235
eval boards to either load and run from ram using the dBug moniter as
the boot deviced (Board setup as shipped from the factory), or it
allows the user to Boot his code from flash he loads onto the eval
board. The code changes between the two are based on the selected
linker script using a variable in the script. The options to the
linker are used to override the default linker script and select
which options to configure at boot either from flash, or from ram:
-qnolinkcmds -T linkcmdsflash
If no options are given the standard linker sript assumes dBug was
used to set up the board and the user is going to load his program
to RAM.
sections required by newer gcc versions.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
clock/clock.c, console/console.c, include/bsp.h, include/coverhd.h,
include/tm27.h, network/network.c, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/init5235.c, startup/linkcmds,
startup/linkcmdsflash, startup/linkcmdsram, timer/timer.c: New files.
