* console/debugio.c: Add BSP_poll_char.
* README: Remove more ITRON references.
* configure.ac: Add mcf5225x BSP.
* README: CONFIGURE_DISABLE_CLASSIC_NOTEPADS is typo of
CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS. Fix it.
* make/custom/mcf52235.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/mcf52235.cfg: New (relocated from /make/custom).
* console/console.c: Reflect termios_baud_to_number having been
renamed to rtems_termios_baud_to_number.
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* startup/init52235.c: Update for boot_card command line change.
* startup/linkcmds: Add .data.* for the C++ test.
* include/bsp.c: Add BSP_SMALL_MEMORY.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Use shared stub coverhd.h
* include/coverhd.h: Removed.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* clock/clock.c: include "../../../shared/clockdrv_shell.h".
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
PR 1322/bsps
* include/bspopts.h.in: Remove.
PR 1322/bsps
* configure.ac, include/bspopts.h.in: Make letting boot_card() handle
work area allocation mandatory. Rename
RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to BSP_BOOTCARD_OPTIONS.
* Makefile.am, configure.ac, include/bspopts.h.in: Use standardized
bsp_cleanup() which can optionally print a message, poll for user to
press key, and call bsp_reset(). Using this eliminates the various
bsp_cleanup() implementations which had their own implementation and
variety of string constants.
* startup/bspclean.c: Removed.
* Makefile.am: Split out bspstart contents. Move cache code to libcpu.
* startup/bspgetcpuclockspeed.c: New file.
* startup/bspstart.c: Removed.
* include/bsp.h: Remove unnecessary boilerplate comments.
* Makefile.am, start/start.S, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* Makefile.am, configure.ac, startup/bspstart.c: Add use of
bsp_get_work_area() in its own file and rely on BSP Framework to
perform more initialization. Remove unnecessary includes of
rtems/libio.h and rtems/libcsupport.h.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* timer/timer.c: Convert to "bool".
* timer/timer.c: Eliminate empty function from every benchmark timer
driver. Fix spelling.
* timer/timer.c: Rename timer driver methods to follow RTEMS
programming conventions.
* clock/clock.c, startup/init52235.c: Add missing prototypes.
* Makefile.am, console/console.c: Split debug IO code into separate
file.
* console/debugio.c: New file.
* startup/cfinit.c, startup/init52235.c: Missed the last patch.
* mcf52235/README, mcf52235/gdb-init, mcf52235/clock/clock.c,
mcf52235/console/console.c, mcf52235/include/bsp.h,
mcf52235/include/coverhd.h, mcf52235/start/start.S,
mcf52235/startup/bspclean.c, mcf52235/startup/bspstart.c,
mcf52235/startup/linkcmds, mcf52235/timer/timer.c: Cleaned up
white space and code formmated to adhere to RTEMS standards. Fixed
a bug in the nano seconds since last tick support. Fixed a bug
with the location of the start stack (no longer within
.bss). Removed double definition of IPSBAR and some type defs
etc.. Added timing test overhead results.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs,
clock/clock.c, configure.ac, console/console.c, gdb-init,
include/bsp.h, include/bspopts.h.in, include/coverhd.h,
include/tm27.h, preinstall.am, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/cfinit.c, startup/init52235.c,
startup/linkcmds, timer/timer.c: New.
