* | RTEMS: Delete ChangeLog files. | Gedare Bloom | 2013-03-08 | 1 | -123/+0 |
| | | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | ||||
* | 2011-02-25 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-25 | 1 | -0/+6 |
| | | | | | | * configure.ac: Remove RTEMS_CANONICAL_TARGET_CPU. Remove AC_ARG_VAR([RTEMS_BSP],[]). Add RTEMS_ENV_RTEMSBSP. | ||||
* | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-02 | 1 | -0/+4 |
| | | | | * configure.ac: Require autoconf-2.68, automake-1.11.1. | ||||
* | 2008-03-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-03-11 | 1 | -0/+4 |
| | | | | * runtest: Skip all fatal error tests. | ||||
* | 2007-09-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-09-04 | 1 | -0/+5 |
| | | | | | * runtest: Add capture to list of interative tests to skip in batch mode. | ||||
* | 2007-01-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-26 | 1 | -0/+4 |
| | | | | * Makefile.am: Use MKDIR_P instead of mkdir_p. | ||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 1 | -0/+4 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 1 | -0/+4 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 1 | -0/+4 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 1 | -0/+5 |
| | | | | | * Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 1 | -0/+4 |
| | | | | * Makefile.am: Reworked. | ||||
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-09 | 1 | -0/+4 |
| | | | | * Makefile.am: Misc cleanups and fixes. | ||||
* | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-18 | 1 | -0/+4 |
| | | | | * Makefile.am: Reflect having moved aclocal/. | ||||
* | Fix broken ChangeLog entries. | Ralf Corsepius | 2003-08-18 | 1 | -1/+1 |
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 1 | -0/+4 |
| | | | | Makefile.am: Reflect having moved automake. | ||||
* | 2003-08-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-08-14 | 1 | -0/+4 |
| | | | | * runtest: Add fileio to list of interactive tests. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 1 | -0/+4 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 1 | -0/+4 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 1 | -0/+4 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-09 | 1 | -0/+5 |
| | | | | | * configure.ac: Remove RTEMS_ENV_RTEMS_BSP, add AC_ARG_VAR(RTEMS_BSP)-hack instead. | ||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 1 | -0/+6 |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | ||||
* | 2002-09-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-09-08 | 1 | -0/+4 |
| | | | | * Makefile.am: Don't use RTEMS_TOPdir in ACLOCAL_AMFLAGS. | ||||
* | 2002-07-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-27 | 1 | -0/+5 |
| | | | | | * Makefile.am: Add transform and bsptools_bindir hacks. * configure.ac: Add RTEMS_ENV_RTEMSBSP. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -0/+7 |
| | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-30 | 1 | -0/+4 |
| | | | | * Makefile.am: Adapt to automake-1.5. | ||||
* | 2002-01-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-04 | 1 | -0/+12 |
* changes: Removed. * ChangeLog: New file. This must have slipped through in some automated changes. 2001-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. |
