path: root/c/src/lib/libbsp/m68k/mcf5206elite/startup/gdbinit (follow)
* bsps: Move startup files to bspsSebastian Huber2018-04-201-217/+0
| | | | | | | | Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285.
* Remove CVS Id Strings (manual edits after script)Joel Sherrill2012-05-111-3/+0
| | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | * README, console/console.c, i2c/i2c.c, i2c/i2cdrv.c, include/bsp.h, include/ds1307.h, include/i2c.h, include/i2cdrv.h, include/nvram.h, nvram/nvram.c, start/start.S, startup/bspclean.c, startup/bspstart.c, startup/gdbinit, startup/init5206e.c, startup/linkcmds, startup/linkcmds.flash, tod/ds1307.c, tod/todcfg.c, tools/runtest: URL for license changed.
* 2001-10-26 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2001-10-261-0/+220
* New BSP for MCF5206eLITE evaluation board BSP. * ChangeLog, README, bsp_specs, configure.ac, console/console.c, console/.cvsignore, i2c/i2c.c, i2c/i2cdrv.c, i2c/.cvsignore, include/bsp.h, include/bspopts.h.in, include/coverhd.h, include/ds1307.h, include/i2c.h, include/i2cdrv.h, include/nvram.h, include/.cvsignore, nvram/nvram.c, nvram/.cvsignore, start/start.S, start/.cvsignore, startup/bspclean.c, startup/bspstart.c, startup/gdbinit, startup/init5206e.c, startup/linkcmds, startup/linkcmds.flash, startup/.cvsignore, times, tod/ds1307.c, tod/todcfg.c, tod/.cvsignore, tools/.cvsignore, tools/configure.ac, tools/runtest, tools/changes, wrapup/.cvsignore, .cvsignore: New files.
