* include/bsp.h startup/init5206e.c:
* startup/init5206e.c: Remove warnings.
* startup/init5206e.c: Make prototype of CopyDataClearBSSAndStart
global.
* include/i2c.h (i2c_transfer_done): Fix type mismatch.
* tod/ds1307.c (ds1307_set_time): Fix broken prototype.
* make/custom/mcf5206elite.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/mcf5206elite.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* include/bsp.h: Eliminate BSPs defining NUMBER_OF_TERMIOS_PORTS.
Should be automatically handled by confdefs.h or the application.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* start/start.S: Update for boot_card command line change.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Remove noinst_PROGRAMS (Unused).
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* include/bsp.h: Remove unnecessary boilerplate comments.
* Makefile.am, startup/linkcmds, startup/linkcmds.flash: Use top level
shared bsp_get_work_area() implementation.
* Makefile.am, configure.ac, start/start.S, startup/linkcmds: Add use
of bsp_get_work_area() in its own file and rely on BSP Framework to
perform more initialization. Remove unnecessary includes of
rtems/libio.h and rtems/libcsupport.h.
* startup/bspstart.c: Removed.
* Makefile.am, include/bsp.h: Review of all bsp_cleanup()
implementations. In this phase, all prototypes were removed from
bsp.h and empty implementations were removed and made to use the
shared stub.
* startup/bspclean.c: Removed.
* tod/todcfg.c: Convert to "bool".
* i2c/i2c.c, i2c/i2cdrv.c: Convert to "bool".
* startup/init5206e.c: Add missing prototypes.
* Makefile.am: Rework to avoid .rel files.
* startup/bspstart.c: Refactored and renamed initialization routines to
rtems_initialize_data_structures, rtems_initialize_before_drivers,
rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
* startup/linkcmds, startup/linkcmds.flash: Add wildcard to
gcc_except_table section so programs compiled with gcc 4.3.x can
link.
* include/bsp.h, startup/bspstart.c: Eliminate copies of the
Configuration Table. Use the RTEMS provided accessor macros to obtain
configuration fields.
* include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field
from CPU Table to Configuration Table. Eliminate CPU Table from all
ports. Delete references to CPU Table in all forms.
* Makefile.am, startup/bspstart.c: Moved most of the remaining CPU
Table fields to the Configuration Table. This included
pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* startup/bspstart.c: Eliminate the interrupt_vector_table field in the
m68k CPU Table since it is never read.
* startup/linkcmds: Handle .data.* sections
* bsp_specs: Remove qrtems_debug.
* Makefile.am: Add dummy printk support so all tests link.
* startup/bspstart.c: Remove assignments of
Cpu_table.do_zero_of_workspace to TRUE since TRUE is the default
value in boot_card.c
* Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a
file and simplified initialization.
* Makefile.am: Remove superfluous -DASM.
* startup/linkcmds, startup/linkcmds.flash: Add sections required by
newer gcc versions.
* Makefile.am: Add preinstall.am.
* include/bsp.h: New header guard.
* include/bsp.h: Correct type of symbols from linkcmds to compile with
gcc 4.x.
* tod/todcfg.c: size_t RTC_Count.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
