Update #3285.
* configure.ac: Add RTEMS_BSP_LINKCMDS.
* make/custom/m5484FireEngine.cfg: Remove RTEMS_LINKCMDS.
* make/custom/COBRA5475.cfg: Remove RTEMS_LINKCMDS.
* make/custom/genmcf548x.inc: Remove LDFLAGS.
* startup/linkcmds: Remove (Renamed into linkcmds).
* startup/linkcmds.m5484FireEngine: New (Renamed from linkcmds).
* Makefile.am: Rework linkcmds handling.
* make/custom/genmcf548x.inc: New (Renamed from genmcf548x.cfg).
* make/custom/genmcf548x.cfg: Removed.
* make/custom/COBRA5475.cfg, make/custom/m5484FireEngine.cfg:
Include make/custom/genmcf548x.inc.
