PR 562/bsps
* Makefile.am: Remove references to m68k-gdbstub.c,
rtems-gdbstub-glue.c.
network/Makefile.am, startup/Makefile.am, timer/Makefile.am.
Use automake-compilation rules.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am:
Remove.
* wrapup/Makefile.am: Reflect changes to libcpu.
* Makefile.am: Remove non-existing file "times" from EXTRA_DIST.
* configure.ac: Add AM_CONDITIONAL(HAS_FPSP).
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* network/Makefile.am: Cosmetics.
* wrapup/Makefile.am: PR217 required that the idle task be moved to
libcpu so it could be more acutely aware of the CPU model. This
file was modified to pick up the idle task from there.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* Per PR260 eliminate use of make-target-options. This impacted
RTEMS allowing a distinction between the CPU32 and CPU32+ in the
SuperCore and required that the m68k optimized memcpy be moved
to libcpu.
* wrapup/Makefile.am: Pick up memcpy.o from libcpu.
converted to automake.
--target=m68k-rtems \
--enable-cxx \
--disable-posix \
--enable-rdbg \
--disable-networking \
--enable-multiprocessing \
--disable-tests
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
all bsp_specs.
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
and automake.
reorg-bsp_specs.sh script.
significantly.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
was done based on the 3.6.0 release and had to be autoconf'ed locally.
It is turned on is the bsp enables it and it is not explicitly disabled
via the configure option --disable-tcpip. As many warnings as possible
were removed locally after the code was merged. Only the gen68360
and mvme136 bsps were compiled this way.
The ka9q port and network driver were submitted by Eric Norum
(eric@skatter.USask.Ca).
The network demo programs are not included in the tree at this point.
be resolved.
