path: root/c/src/lib/libbsp/m68k/gen68360/configure.in (follow)
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-121-38/+0
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-181-0/+1
| | | | | | | * configure.in: Add bspopts.h. * include/.cvsignore: Add bspopts.h*, stamp-h*. * include/Makefile.am: Use *_HEADERS instead of *H_FILES. * include/bsp.h: Include bspopts.h.
* 2001-05-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-111-1/+1
| | | | * configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]).
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-081-4/+6
* Patch rtems-rc-20000104-10.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-101-0/+35
that converts the m68k directory to automake. NOTE: This one is fully tested by building *all* bsps with ../../rtems-rc-20000104/configure \ --target=m68k-rtems \ --prefix=/tmp/rtems \ --enable-cxx \ --disable-posix \ --enable-rdbg \ --disable-networking \ --enable-maintainer-mode \ --enable-multiprocessing \ --disable-tests make
