* | 2008-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-30 | 1 | -489/+0 |
| | | | | | | * Makefile.am: Eliminate bsp.am. Build startup files as side-effect of building libbspstart.a, using automake-rules. * start/startfor340only.S: Remove (Unused). | ||||
* | Remove duplicate white lines. | Ralf Corsepius | 2004-04-21 | 1 | -1/+0 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-21 | 1 | -3/+3 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -1/+0 |
* | * start/start.S: Include <rtems/asm.h> instead of <asm.h>. | Ralf Corsepius | 2004-04-02 | 1 | -1/+1 |
| | | | | * start/startfor340only.S: Include <rtems/asm.h> instead of <asm.h>. | ||||
| | | | | | | | | * clock/ckinit.c, console/Modif_cpu_asm.S, console/console.c, console/m340uart.c, include/bsp.h, include/m340timer.h, include/m340uart.h, start/start.S, start/startfor340only.S, startup/bspclean.c, startup/bspstart.c, startup/dumpanic.c, timer/timer.c: URL for license changed. | ||||
* | All m68k BSPs now build with new ELF style linkcmds. | Joel Sherrill | 2000-01-13 | 1 | -7/+0 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to rename all | Joel Sherrill | 1998-12-14 | 1 | -0/+499 |
.s files to .S in conformance with GNU conventions. This is a minor step along the way to supporting automake. |
