line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* console/console.c, include/m340uart.h: Use new shared
termios_baud_to_number() routine.
* clock/ckinit.c, console/m340uart.c, include/bsp.h,
include/m340uart.h, startup/bspstart.c: Convert to using c99 fixed
size types.
* clock/ckinit.c, console/Modif_cpu_asm.S, console/console.c,
console/m340uart.c, include/bsp.h, include/m340timer.h,
include/m340uart.h, start/start.S, start/startfor340only.S,
startup/bspclean.c, startup/bspstart.c, startup/dumpanic.c,
timer/timer.c: URL for license changed.
Geoffroy Montel <g_montel@yahoo.com>.
