closes #2543.
* Makefile.am, configure.ac, clock/ckinit.c, startup/linkcmds: Add use
of bsp_get_work_area() in its own file and rely on BSP Framework to
perform more initialization. Remove unnecessary includes of
rtems/libio.h and rtems/libcsupport.h.
* startup/bspstart.c: Removed.
* clock/ckinit.c: The Shared Memory Driver no longer requires the
special IOCTL in Clock_control. This was a hack which has existed
since before the Classic API Timer Manager was implemented. All
implementations of and references to Clock_control were removed.
* README, clock/ckinit.c, include/bsp.h, startup/bspstart.c: Eliminate
copies of the Configuration Table. Use the RTEMS provided accessor
macros to obtain configuration fields.
* c/src/lib/libbsp/m68k/gen68302/clock/ckinit.c,
c/src/lib/libbsp/m68k/gen68302/console/console.c,
c/src/lib/libbsp/m68k/gen68302/network/network.c,
c/src/lib/libbsp/m68k/gen68302/timer/timer.c: Include
<rtems/m68k/m68302.h> instead of <m68302.h>.
* clock/ckinit.c, console/console.c, include/bsp.h,
network/network.c, startup/bspstart.c, timer/timer.c: Convert to
using c99 fixed size types.
start/start.S, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, timer/timer.c: URL for license changed.
* clock/ckinit.c: Do not just set the IMR, OR the enable bit in.
like signal dispatching.
