path: root/c/src/lib/libbsp/m68k/efi68k/start/Makefile.am (follow)
* 2004-01-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-071-28/+0
| | | | | | * start/Makefile.am: Remove. * Makefile.am: Merge-in start/Makefile.am. * configure.ac: Reflect changes above.
* 2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-131-6/+6
| | | | | * start/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. * startup/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-0/+4
| | | | | * start/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * startup/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* 2003-12-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-101-15/+7
| | | | | | * start/Makefile.am: Misc cleanups and fixes. * startup/Makefile.am: Misc cleanups and fixes. * wrapup/Makefile.am: Misc cleanups and fixes.
* 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-021-1/+1
| | | | | | | | | | * clock/Makefile.am: Remove all-local: $(ARCH). * console/Makefile.am: Remove all-local: $(ARCH). * spurious/Makefile.am: Remove all-local: $(ARCH). * start/Makefile.am: Remove all-local: $(ARCH). * startup/Makefile.am: Remove all-local: $(ARCH). * timer/Makefile.am: Remove all-local: $(ARCH). * wrapup/Makefile.am: Remove all-local: $(ARCH).
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-3/+3
| | | | | | | | | | | | Makefile.am: Reflect having moved automake. clock/Makefile.am: Reflect having moved automake. console/Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. spurious/Makefile.am: Reflect having moved automake. start/Makefile.am: Reflect having moved automake. startup/Makefile.am: Reflect having moved automake. timer/Makefile.am: Reflect having moved automake. wrapup/Makefile.am: Reflect having moved automake.
* 2002-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-191-1/+0
| | | | | | | | | * clock/Makefile.am: Don't include @RTEMS_BSP@.cfg. * console/Makefile.am: Don't include @RTEMS_BSP@.cfg. * spurious/Makefile.am: Don't include @RTEMS_BSP@.cfg. * start/Makefile.am: Don't include @RTEMS_BSP@.cfg. * startup/Makefile.am: Don't include @RTEMS_BSP@.cfg. * timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-121-1/+3
| | | | * start/Makefile.am: Use install-data-local to install startfile.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-6/+6
| | | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * spurious/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-07-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-211-6/+5
| | | | | * start/Makefile.am: Eliminate PGM. Add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o.
| | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * console/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * spurious/Makefile.am: Remove AUTOMAKE_OPTIONS. * start/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * timer/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | * clock/Makefile.am, console/Makefile.am, spurious/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include compile.am
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-2/+2
* Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff fromJoel Sherrill2000-01-311-0/+32
Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams
