Per John S. Gwynne <jgwynne@mrcday.com>, there are no longer any
users of these boards so we are removing them.
* efi332/.cvsignore, efi332/ChangeLog, efi332/Makefile.am,
efi332/README, efi332/bsp_specs, efi332/configure.ac, efi332/times,
efi332/clock/.cvsignore, efi332/clock/Makefile.am,
efi332/clock/ckinit.c, efi332/console/.cvsignore,
efi332/console/Makefile.am, efi332/console/console.c,
efi332/include/.cvsignore, efi332/include/bsp.h,
efi332/include/efi332.h, efi332/misc/dotests, efi332/misc/gdbinit68,
efi332/misc/interr.c, efi332/spurious/.cvsignore,
efi332/spurious/Makefile.am, efi332/spurious/spinit.c,
efi332/start/.cvsignore, efi332/start/Makefile.am,
efi332/start/except_vect_332_ROM.S, efi332/start/ram_init.ld,
efi332/start/ram_init.sed, efi332/start/start.c,
efi332/startup/.cvsignore, efi332/startup/Makefile.am,
efi332/startup/bspclean.c, efi332/startup/bspstart.c,
efi332/startup/linkcmds, efi332/startup/linkcmds_ROM,
efi332/timer/.cvsignore, efi332/timer/Makefile.am,
efi332/timer/timer.c, efi332/wrapup/.cvsignore,
efi332/wrapup/Makefile.am, efi68k/.cvsignore, efi68k/ChangeLog,
efi68k/Makefile.am, efi68k/README, efi68k/bsp_specs,
efi68k/configure.ac, efi68k/times, efi68k/clock/.cvsignore,
efi68k/clock/Makefile.am, efi68k/clock/ckinit.c,
efi68k/console/.cvsignore, efi68k/console/Makefile.am,
efi68k/console/console.c, efi68k/include/.cvsignore,
efi68k/include/16550.h, efi68k/include/DP8570A.h,
efi68k/include/bsp.h, efi68k/include/efi68k.h,
efi68k/spurious/.cvsignore, efi68k/spurious/Makefile.am,
efi68k/spurious/spinit.c, efi68k/start/.cvsignore,
efi68k/start/start.c, efi68k/startup/.cvsignore,
efi68k/startup/Makefile.am, efi68k/startup/bspclean.c,
efi68k/startup/bspstart.c, efi68k/startup/efi68k_tcp.c,
efi68k/startup/efi68k_wd.c, efi68k/startup/linkcmds,
efi68k/startup/m68k-stub.c, efi68k/startup/setvec.c,
efi68k/timer/.cvsignore, efi68k/timer/Makefile.am,
efi68k/timer/timer.c, efi68k/wrapup/.cvsignore,
efi68k/wrapup/Makefile.am: Removed.
* startup/Makefile.am: Remove S_FILES.
* spurious/Makefile.am: Cosmetics.
* start/Makefile.am: Cosmetics.
* spurious/Makefile.am: Remove all-local: $(ARCH).
PR 483/bsps
* start/start.c, startup/bspstart.c: Spurious interrupt handlers cannot
be installed until RTEMS has initialized the vector table.
* clock/ckinit.c, console/console.c, include/bsp.h, misc/interr.c,
spurious/spinit.c, startup/bspclean.c, startup/bspstart.c,
timer/timer.c: URL for license changed.
spurious/Makefile.am: Reflect having moved automake.
* startup/Makefile.am: Remove USE_INIT_FINI.
* spurious/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Various fixes to get it compiling again.
* spurious/Makefile.am: Use .$(OBJEXT) instead of .o.
* startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds_ROM.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* spurious/Makefile.am: Remove AUTOMAKE_OPTIONS.
* start/start.c: Modified to support generation of ram_init.
* start/ram_init.ld, BSP/start/ram_init.sed: New files.
These changes enable RTEMS to automatically generate
the ram_init file used by gdb with the BDM patches. The 332 has
on-board chip select lines (for RAM and FLASH) that must be
configured before use of these peripherals. These patches parse
data from start.c where the chip select lines are configured in
the runtime executable and automatically generates the gdb
initialization file using the same settings. A great time saver.
A similar file, ram_init_FW (flash writable), is also generated
that the flash programming tool uses.
* start/Makefile.am: Modified to support above.
* CPU/sim.h: Modified to support above.
* startup/except_vect_332_ROM.S: Moved to start so it would not
be included in libbsp.a. Moving it to start ensures it is
available as a single object file.
* start/except_vect_332_ROM.S: Moved from startup.
* startup/linkcmds, startup/linkcmds_ROM: Fixes to the memory map
shown in the comments.
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
* clock/Makefile.am, console/Makefile.am, spurious/Makefile.am,
converted to automake.
and memory layout. Next step is to share the same bsp_pretasking_hook.
for the gen68360 that let it work with ELF and C++ exceptions. This
was used as the basis for changes to EVERY m68k bsp_specs and linkcmds.
Before this modification is over, the layout of the starting stack,
heap, and workspace will likely be modified for every m68k BSP. Then
they will all be very similar.
--target=m68k-rtems \
--enable-cxx \
--disable-posix \
--enable-rdbg \
--disable-networking \
--enable-multiprocessing \
--disable-tests
dependencies of "Makefile".
--enable-maintainer-mode.
ncurses, and zlib for RTEMS.
link even if they do not actually support Ada interrupts.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
problems that prevented the 19990302 snapshot from running on
the efi332.
I'm happy to report that rtems-19990302 is running on the efi332
board. I have enclosed a few minor patches below to the efi332 bsp. All
patches are within that library but one. make/custom/efi332.cfg has a
patch to select the right CPU_CFLAGS (at one time -m68332 was a
problem... -mcpu32 or -m68332 work fine now).
by newlib.
component.
based on the GNU tools. This usually involved correcting the
type of bsp_start(), bsp_cleanup(), adjusting the start code to
call the right start routine (the shared boot_card()), and then
removing code from bsp_start() which was performed in the new
boot_card()/main() path.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
