path: root/c/src/lib/libbsp/m68k/efi332/configure.ac (follow)
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-071-26/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Per John S. Gwynne <jgwynne@mrcday.com>, there are no longer any users of these boards so we are removing them. * efi332/.cvsignore, efi332/ChangeLog, efi332/Makefile.am, efi332/README, efi332/bsp_specs, efi332/configure.ac, efi332/times, efi332/clock/.cvsignore, efi332/clock/Makefile.am, efi332/clock/ckinit.c, efi332/console/.cvsignore, efi332/console/Makefile.am, efi332/console/console.c, efi332/include/.cvsignore, efi332/include/bsp.h, efi332/include/efi332.h, efi332/misc/dotests, efi332/misc/gdbinit68, efi332/misc/interr.c, efi332/spurious/.cvsignore, efi332/spurious/Makefile.am, efi332/spurious/spinit.c, efi332/start/.cvsignore, efi332/start/Makefile.am, efi332/start/except_vect_332_ROM.S, efi332/start/ram_init.ld, efi332/start/ram_init.sed, efi332/start/start.c, efi332/startup/.cvsignore, efi332/startup/Makefile.am, efi332/startup/bspclean.c, efi332/startup/bspstart.c, efi332/startup/linkcmds, efi332/startup/linkcmds_ROM, efi332/timer/.cvsignore, efi332/timer/Makefile.am, efi332/timer/timer.c, efi332/wrapup/.cvsignore, efi332/wrapup/Makefile.am, efi68k/.cvsignore, efi68k/ChangeLog, efi68k/Makefile.am, efi68k/README, efi68k/bsp_specs, efi68k/configure.ac, efi68k/times, efi68k/clock/.cvsignore, efi68k/clock/Makefile.am, efi68k/clock/ckinit.c, efi68k/console/.cvsignore, efi68k/console/Makefile.am, efi68k/console/console.c, efi68k/include/.cvsignore, efi68k/include/16550.h, efi68k/include/DP8570A.h, efi68k/include/bsp.h, efi68k/include/efi68k.h, efi68k/spurious/.cvsignore, efi68k/spurious/Makefile.am, efi68k/spurious/spinit.c, efi68k/start/.cvsignore, efi68k/start/start.c, efi68k/startup/.cvsignore, efi68k/startup/Makefile.am, efi68k/startup/bspclean.c, efi68k/startup/bspstart.c, efi68k/startup/efi68k_tcp.c, efi68k/startup/efi68k_wd.c, efi68k/startup/linkcmds, efi68k/startup/m68k-stub.c, efi68k/startup/setvec.c, efi68k/timer/.cvsignore, efi68k/timer/Makefile.am, efi68k/timer/timer.c, efi68k/wrapup/.cvsignore, efi68k/wrapup/Makefile.am: Removed.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-2/+2
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-09-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-291-3/+0
| | | | | | | * Makefile.am: Merge-in include/Makefile.am. Reflect changes to bsp.am. * include/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-111-1/+1
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-111-1/+0
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-111-1/+1
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
| | | | * configure.ac: AC_PREREQ(2.57).
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-2/+2
| | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * console/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * spurious/Makefile.am: Remove AUTOMAKE_OPTIONS. * start/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * timer/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-031-7/+1
| | | | * configure.ac: Introduce RTEMS_BSP_CONFIGURE.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-121-0/+36
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
