path: root/c/src/lib/libbsp/m68k/efi332/clock/Makefile.am (follow)
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-071-30/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Per John S. Gwynne <jgwynne@mrcday.com>, there are no longer any users of these boards so we are removing them. * efi332/.cvsignore, efi332/ChangeLog, efi332/Makefile.am, efi332/README, efi332/bsp_specs, efi332/configure.ac, efi332/times, efi332/clock/.cvsignore, efi332/clock/Makefile.am, efi332/clock/ckinit.c, efi332/console/.cvsignore, efi332/console/Makefile.am, efi332/console/console.c, efi332/include/.cvsignore, efi332/include/bsp.h, efi332/include/efi332.h, efi332/misc/dotests, efi332/misc/gdbinit68, efi332/misc/interr.c, efi332/spurious/.cvsignore, efi332/spurious/Makefile.am, efi332/spurious/spinit.c, efi332/start/.cvsignore, efi332/start/Makefile.am, efi332/start/except_vect_332_ROM.S, efi332/start/ram_init.ld, efi332/start/ram_init.sed, efi332/start/start.c, efi332/startup/.cvsignore, efi332/startup/Makefile.am, efi332/startup/bspclean.c, efi332/startup/bspstart.c, efi332/startup/linkcmds, efi332/startup/linkcmds_ROM, efi332/timer/.cvsignore, efi332/timer/Makefile.am, efi332/timer/timer.c, efi332/wrapup/.cvsignore, efi332/wrapup/Makefile.am, efi68k/.cvsignore, efi68k/ChangeLog, efi68k/Makefile.am, efi68k/README, efi68k/bsp_specs, efi68k/configure.ac, efi68k/times, efi68k/clock/.cvsignore, efi68k/clock/Makefile.am, efi68k/clock/ckinit.c, efi68k/console/.cvsignore, efi68k/console/Makefile.am, efi68k/console/console.c, efi68k/include/.cvsignore, efi68k/include/16550.h, efi68k/include/DP8570A.h, efi68k/include/bsp.h, efi68k/include/efi68k.h, efi68k/spurious/.cvsignore, efi68k/spurious/Makefile.am, efi68k/spurious/spinit.c, efi68k/start/.cvsignore, efi68k/start/start.c, efi68k/startup/.cvsignore, efi68k/startup/Makefile.am, efi68k/startup/bspclean.c, efi68k/startup/bspstart.c, efi68k/startup/efi68k_tcp.c, efi68k/startup/efi68k_wd.c, efi68k/startup/linkcmds, efi68k/startup/m68k-stub.c, efi68k/startup/setvec.c, efi68k/timer/.cvsignore, efi68k/timer/Makefile.am, efi68k/timer/timer.c, efi68k/wrapup/.cvsignore, efi68k/wrapup/Makefile.am: Removed.
* 2003-12-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-031-1/+0
| | | | | | | | | | | * Makefile.am: Add preinstallation dirstamp support. * clock/Makefile.am: Cosmetics. * console/Makefile.am: Cosmetics. * spurious/Makefile.am: Cosmetics. * start/Makefile.am: Cosmetics. * startup/Makefile.am: Cosmetics. * timer/Makefile.am: Cosmetics. * wrapup/Makefile.am: Cosmetics.
* 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-021-1/+1
| | | | | | | | | | * clock/Makefile.am: Remove all-local: $(ARCH). * console/Makefile.am: Remove all-local: $(ARCH). * spurious/Makefile.am: Remove all-local: $(ARCH). * start/Makefile.am: Remove all-local: $(ARCH). * startup/Makefile.am: Remove all-local: $(ARCH). * timer/Makefile.am: Remove all-local: $(ARCH). * wrapup/Makefile.am: Remove all-local: $(ARCH).
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-3/+3
| | | | | | | | | | | | Makefile.am: Reflect having moved automake. clock/Makefile.am: Reflect having moved automake. console/Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. spurious/Makefile.am: Reflect having moved automake. start/Makefile.am: Reflect having moved automake. startup/Makefile.am: Reflect having moved automake. timer/Makefile.am: Reflect having moved automake. wrapup/Makefile.am: Reflect having moved automake.
* 2002-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-181-1/+0
| | | | | | | | | | * clock/Makefile.am: Don't include @RTEMS_BSP@.cfg. * console/Makefile.am: Don't include @RTEMS_BSP@.cfg. * spurious/Makefile.am: Don't include @RTEMS_BSP@.cfg. * start/Makefile.am: Don't include @RTEMS_BSP@.cfg. Various fixes to get it compiling again. * startup/Makefile.am: Don't include @RTEMS_BSP@.cfg. * timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-1/+1
| | | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * spurious/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
| | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * console/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * spurious/Makefile.am: Remove AUTOMAKE_OPTIONS. * start/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * timer/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | * clock/Makefile.am, console/Makefile.am, spurious/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include compile.am
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-2/+2
* Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff fromJoel Sherrill2000-01-311-0/+32
Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams
