* dmv152/.cvsignore, dmv152/ChangeLog, dmv152/Makefile.am,
dmv152/bsp_specs, dmv152/configure.ac, dmv152/preinstall.am,
dmv152/times, dmv152/clock/ckinit.c, dmv152/console/console.c,
dmv152/include/.cvsignore, dmv152/include/bsp.h,
dmv152/include/coverhd.h, dmv152/include/tm27.h,
dmv152/spurious/spinit.c, dmv152/startup/bspclean.c,
dmv152/startup/bspstart.c, dmv152/startup/linkcmds,
dmv152/startup/vmeintr.c, dmv152/timer/timer.c,
dmv152/timer/timerisr.S: Removed.
* startup/linkcmds: Handle .data.* sections
* startup/linkcmds: Add sections required by newer gcc versions.
* startup/linkcmds: Add new bss sections .bss.* and .gnu.linkonce.b*.
spurious/spinit.c, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, startup/vmeintr.c, timer/timer.c, timer/timerisr.S:
URL for license changed.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
and memory layout. Next step is to share the same bsp_pretasking_hook.
for the gen68360 that let it work with ELF and C++ exceptions. This
was used as the basis for changes to EVERY m68k bsp_specs and linkcmds.
Before this modification is over, the layout of the starting stack,
heap, and workspace will likely be modified for every m68k BSP. Then
they will all be very similar.
gnu.linkonce* sections are included.
seeing.
<jzamora@avellano.datsi.fi.upm.es>. He debugged enough to let me
know what was wrong and I supplied the code. :)
