* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* spurious/Makefile.am: Remove all-local: $(ARCH).
spurious/Makefile.am: Reflect having moved automake.
* spurious/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* spurious/Makefile.am: Use .$(OBJEXT) instead of .o.
* spurious/Makefile.am: Remove AUTOMAKE_OPTIONS.
* clock/Makefile.am, console/Makefile.am, spurious/Makefile.am,
converted to automake.
