* dmv152/.cvsignore, dmv152/ChangeLog, dmv152/Makefile.am,
dmv152/bsp_specs, dmv152/configure.ac, dmv152/preinstall.am,
dmv152/times, dmv152/clock/ckinit.c, dmv152/console/console.c,
dmv152/include/.cvsignore, dmv152/include/bsp.h,
dmv152/include/coverhd.h, dmv152/include/tm27.h,
dmv152/spurious/spinit.c, dmv152/startup/bspclean.c,
dmv152/startup/bspstart.c, dmv152/startup/linkcmds,
dmv152/startup/vmeintr.c, dmv152/timer/timer.c,
dmv152/timer/timerisr.S: Removed.
* include/bsp.h: New header guard.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* dmv152/include/bsp.h: Include <rtems/zilog/z8536.h> instead of
<zilog/z8536.h>.
* dmv152/include/bsp.h: Include <rtems/zilog/z8530.h> instead of
<zilog/z8530.h>.
* include/bsp.h: Include <rtems/vmeintr.h> instead of <vmeintr.h>.
* startup/vmeintr.c: Include <rtems/vmeintr.h> instead of <vmeintr.h>.
* clock/ckinit.c, console/console.c, include/bsp.h,
spurious/spinit.c, startup/bspstart.c, startup/vmeintr.c,
timer/timer.c: Convert to using c99 fixed size types.
Reflect changes to bsp.am.
spurious/spinit.c, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, startup/vmeintr.c, timer/timer.c, timer/timerisr.S:
URL for license changed.
spurious/Makefile.am: Reflect having moved automake.
* spurious/Makefile.am: Remove AUTOMAKE_OPTIONS.
converted to automake.
--target=m68k-rtems \
--enable-cxx \
--disable-posix \
--enable-rdbg \
--disable-networking \
--enable-multiprocessing \
--disable-tests
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
both ports.
to lib/include.
be resolved.
like signal dispatching.
IDLE task priority changed from 0 to 255 during initialization.
