* shared/start.S, shared/mvme/mvme16x_hw.h: Check on MVME167 at OAR
after RTC replaced.
* shared/gdbstub/m68k-stub.c:
* mcf5206elite/tools/runtest: Fix typo where license said
found in found in.
* acinclude.m4: Add mcf5225x BSP.
* shared/start/start.S: Update for boot_card command line change.
* shared/m68kbspgetworkarea.c: Removed.
* shared/m68kbspgetworkarea.c: Add use of bsp_get_work_area() in its
own file and rely on BSP Framework to perform more initialization.
Remove unnecessary includes of rtems/libio.h and rtems/libcsupport.h.
* shared/m68kpretaskinghook.c: Removed.
* shared/gdbstub/m68k-stub.c: Convert to "bool".
* acinclude.m4: Add mcf52235 and mcf5329. Regenerate.
* shared/m68kbspgetworkarea.c: Move extern of global symbols from
linkcmds outside function.
* shared/bspspuriousinit.c: Add missing prototypes.
added support for an optional separate heap area.
* acinclude.m4: Regeneration to add new BSPs.
added genmcf548x BSP
* acinclude.m4: Regenerated.
* mcf5223x/include/mcf5223x.h: New.
* shared/m68kbspgetworkarea.c: Fix extern type to RamSize.
* shared/m68kpretaskinghook.c: Do not handle the RAM allocation if
the BSP is handling it.
* acinclude.m4: Add the mcf52235 BSP.
* shared/m68kpretaskinghook.c: Add capability for bootcard.c BSP
Initialization Framework to ask the BSP where it has memory for the
RTEMS Workspace and C Program Heap. These collectively are referred
to as work area. If the BSP supports this, then it does not have to
include code to split the available memory between the two areas.
This reduces the amount of code in the BSP specific bspstart.c file.
Additionally, the shared framework can dirty the work area memory.
Until most/all BSPs support this new capability, if the BSP supports
this, it should call RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from
its configure.ac. When the transition is complete, this autoconf
macro can be removed.
* shared/m68kbspgetworkarea.c: New file.
* shared/m68kpretaskinghook.c: Eliminate copies of the Configuration
Table. Use the RTEMS provided accessor macros to obtain configuration
fields.
* dmv152/.cvsignore, dmv152/ChangeLog, dmv152/Makefile.am,
dmv152/bsp_specs, dmv152/configure.ac, dmv152/preinstall.am,
dmv152/times, dmv152/clock/ckinit.c, dmv152/console/console.c,
dmv152/include/.cvsignore, dmv152/include/bsp.h,
dmv152/include/coverhd.h, dmv152/include/tm27.h,
dmv152/spurious/spinit.c, dmv152/startup/bspclean.c,
dmv152/startup/bspstart.c, dmv152/startup/linkcmds,
dmv152/startup/vmeintr.c, dmv152/timer/timer.c,
dmv152/timer/timerisr.S: Removed.
* mcf5206elite/tools/runtest: Do not run pppd.exe from batch mode
script.
* Makefile.am: Merge-in shared/Makefile.am.
* ChangeLog: Merge-in shared/ChangeLog.
* configure.ac: Remove shared/Makefile.am.
* acinclude.m4: Add the av5282 BSP.
* acinclude.m4: Added mcf5235.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
times, console/.cvsignore, console/console-io.c, include/.cvsignore,
include/bsp.h, include/coverhd.h, include/tm27.h, network/network.c,
start/.cvsignore, start/start.S, startup/.cvsignore,
startup/bspclean.c, startup/bspstart.c, startup/init5272.c,
startup/linkcmds: New files.
* acinclude.m4: Regenerate.
* configure.ac: RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY]).
* Makefile.am: Use @RTEMS_BSP_FAMILY@ instead of
$(RTEMS_BSP_FAMILY).
* acinclude.m4: Remove efi68k and efi332 references as they are no
longer in the tree.
Per John S. Gwynne <jgwynne@mrcday.com>, there are no longer any
users of these boards so we are removing them.
* efi332/.cvsignore, efi332/ChangeLog, efi332/Makefile.am,
efi332/README, efi332/bsp_specs, efi332/configure.ac, efi332/times,
efi332/clock/.cvsignore, efi332/clock/Makefile.am,
efi332/clock/ckinit.c, efi332/console/.cvsignore,
efi332/console/Makefile.am, efi332/console/console.c,
efi332/include/.cvsignore, efi332/include/bsp.h,
efi332/include/efi332.h, efi332/misc/dotests, efi332/misc/gdbinit68,
efi332/misc/interr.c, efi332/spurious/.cvsignore,
efi332/spurious/Makefile.am, efi332/spurious/spinit.c,
efi332/start/.cvsignore, efi332/start/Makefile.am,
efi332/start/except_vect_332_ROM.S, efi332/start/ram_init.ld,
efi332/start/ram_init.sed, efi332/start/start.c,
efi332/startup/.cvsignore, efi332/startup/Makefile.am,
efi332/startup/bspclean.c, efi332/startup/bspstart.c,
efi332/startup/linkcmds, efi332/startup/linkcmds_ROM,
efi332/timer/.cvsignore, efi332/timer/Makefile.am,
efi332/timer/timer.c, efi332/wrapup/.cvsignore,
efi332/wrapup/Makefile.am, efi68k/.cvsignore, efi68k/ChangeLog,
efi68k/Makefile.am, efi68k/README, efi68k/bsp_specs,
efi68k/configure.ac, efi68k/times, efi68k/clock/.cvsignore,
efi68k/clock/Makefile.am, efi68k/clock/ckinit.c,
efi68k/console/.cvsignore, efi68k/console/Makefile.am,
efi68k/console/console.c, efi68k/include/.cvsignore,
efi68k/include/16550.h, efi68k/include/DP8570A.h,
efi68k/include/bsp.h, efi68k/include/efi68k.h,
efi68k/spurious/.cvsignore, efi68k/spurious/Makefile.am,
efi68k/spurious/spinit.c, efi68k/start/.cvsignore,
efi68k/start/start.c, efi68k/startup/.cvsignore,
efi68k/startup/Makefile.am, efi68k/startup/bspclean.c,
efi68k/startup/bspstart.c, efi68k/startup/efi68k_tcp.c,
efi68k/startup/efi68k_wd.c, efi68k/startup/linkcmds,
efi68k/startup/m68k-stub.c, efi68k/startup/setvec.c,
efi68k/timer/.cvsignore, efi68k/timer/Makefile.am,
efi68k/timer/timer.c, efi68k/wrapup/.cvsignore,
efi68k/wrapup/Makefile.am: Removed.
* configure.ac: Remove shared/gdbstub/Makefile.
* acinclude.m4: Reflect changes to bootstrap.
* configure.ac: Remove RTEMS_CHECK_CUSTON_BSP.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
