* | m32r/m32rsim: Remove | Aun-Ali Zaidi | 2015-12-10 | 1 | -71/+0 |
| | | | | updates #2447. | ||||
* | Add console-polled.h and update all BSPs that should use it. | Joel Sherrill | 2014-10-10 | 1 | -0/+4 |
| | | | | | | | | | | | The file console-polled.h provides the prototypes for the three required methods when implementing a single port polled console driver. This paradigm is common on simulators and simple hardware. + Updated the BSPs Makefile.am to make console-polled.h available. + Regenerated the BSPs preinstall.sm. + Updated console support files to include <bsp/console-polled.h>. + Updated console support files to make printk() support method static. | ||||
* | Regenerate all preinstall.am files. | Chris Johns | 2014-08-29 | 1 | -6/+6 |
| | | | | | With this patch the preinstall.am files are in a set order and not dependent on now perl implements a hash. | ||||
* | Regenerate all preinstall.am files. | Joel Sherrill | 2014-08-28 | 1 | -3/+3 |
| | | | | | Apparently, at some point automake output changed and these were not updated. | ||||
* | 2008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-10-02 | 1 | -0/+67 |
* .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac, preinstall.am, console/console-io.c, console/syscalls.S, console/trap0.S, include/.cvsignore, include/bsp.h, include/tm27.h, start/start.S, startup/linkcmds: New files. |
