* Makefile.am: Don't reference non-existing files.
* Makefile.am, configure.ac: runtest for this BSP obsoleted by
rtems-testing/sim-scripts support. Please use those scripts.
* tools/.cvsignore, tools/Makefile.am, tools/configure.ac,
tools/runtest.in: Removed.
* tools/configure.ac: Remove RTEMS_CANONICAL_TARGET_CPU.
Fix package name.
* include/bsp.h:
* timer/timer.c: Include <rtems/btimer.h>.
* tools/configure.ac: Require autoconf-2.68, automake-1.11.1.
* start/start.S: Verify boot_card() is passed a NULL.
* make/custom/m32csim.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/m32csim.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* console/console-io.c: Fix typo.
* start/start.S: Update for boot_card command line change.
* bsp_specs, tools/runtest.in: Move -e start from *link to *startfile
to avoid warning for undefined entry symbol when linking relocatables
with binutils 2.19.
* README: New file.
* .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac,
preinstall.am, console/console-io.c, console/syscalls.S,
include/.cvsignore, include/bsp.h, start/start.S, startup/bspstart.c,
startup/crtn.S, startup/linkcmds, timer/timer.c, tools/.cvsignore,
tools/Makefile.am, tools/configure.ac, tools/runtest.in: New files.
