Update #3285.
Update #2408.
TOD_MILLISECONDS_TO_TICKS().
PR 1869/bsps
* startup/bspclean.c: New file.
* include/tm27.h: Removed.
* ChangeLog, Makefile.am, README, preinstall.am, include/bsp.h,
include/system_conf.h, make/custom/milkymist.cfg, startup/linkcmds:
Complete BSP for Milkymist One supporting Milkymist SOC 1.0.x.
Includes new or updated drivers for:
- Multi-standard video input (PAL/SECAM/NTSC)
- Two DMX512 (RS485) ports
- MIDI IN and MIDI OUT ports
- VGA output
- AC'97 audio
- NOR flash
- 10/100 Ethernet
- Memory card (experimental and incomplete)
- USB host connectors (input devices only)
- RC5 infrared receiver
- RS232 debug port
* ChangeLog, Makefile.am, README, acinclude.m4, configure.ac,
shared/clock/ckinit.c, shared/clock/clock.h,
shared/console/console.c, shared/console/uart.c,
shared/console/uart.h, shared/start/start.S,
shared/startup/bspstart.c, shared/startup/setvec.c,
shared/timer/timer.c, shared/tsmac/dp83848phy.h,
shared/tsmac/tsmac.c, shared/tsmac/tsmac.h: New files.
