* .cvsignore, ChangeLog, Makefile.am, acinclude.m4, configure.ac,
cvme961/.cvsignore, cvme961/ChangeLog, cvme961/Makefile.am,
cvme961/bsp_specs, cvme961/configure.ac, cvme961/times,
cvme961/clock/ckinit.c, cvme961/console/console.c,
cvme961/include/.cvsignore, cvme961/include/bsp.h,
cvme961/include/tm27.h, cvme961/shmsupp/addrconv.c,
cvme961/shmsupp/getcfg.c, cvme961/shmsupp/lock.c,
cvme961/shmsupp/mpisr.c, cvme961/start/start.S,
cvme961/startup/bspclean.c, cvme961/startup/bspstart.c,
cvme961/startup/exit.c, cvme961/startup/linkcmds,
cvme961/startup/setvec.c, cvme961/timer/timer.c,
cvme961/timer/timerisr.S, i960sim/.cvsignore, i960sim/ChangeLog,
i960sim/Makefile.am, i960sim/bsp_specs, i960sim/configure.ac,
i960sim/clock/clockdrv.c, i960sim/console/console-io.c,
i960sim/console/mon-syscalls.S, i960sim/include/.cvsignore,
i960sim/include/bsp.h, i960sim/include/tm27.h, i960sim/start/start.c,
i960sim/startup/bspstart.c, i960sim/startup/linkcmds,
rxgen960/.cvsignore, rxgen960/ChangeLog, rxgen960/Makefile.am,
rxgen960/README, rxgen960/bsp_specs, rxgen960/configure.ac,
rxgen960/clock/ckinit.c, rxgen960/console/concntl.h,
rxgen960/console/console.c, rxgen960/console/serial.c,
rxgen960/console/serial.h, rxgen960/include/.cvsignore,
rxgen960/include/bsp.h, rxgen960/include/rxgen960_config.h,
rxgen960/include/tm27.h, rxgen960/start/rxgen_romld.S,
rxgen960/startup/asmfault.S, rxgen960/startup/asmfault.h,
rxgen960/startup/asmstub.S, rxgen960/startup/asmstub.h,
rxgen960/startup/bspstart.c, rxgen960/startup/cntrltbl.c,
rxgen960/startup/cntrltbl.h, rxgen960/startup/dram.ld,
rxgen960/startup/exit.c, rxgen960/startup/fault.c,
rxgen960/startup/fault.h, rxgen960/startup/faultret.h,
rxgen960/startup/flttbl.c, rxgen960/startup/flttbl.h,
rxgen960/startup/frmstr.c, rxgen960/startup/frmstr.h,
rxgen960/startup/i960.h, rxgen960/startup/ihandler.S,
rxgen960/startup/ihandler.h, rxgen960/startup/intrtbl.c,
rxgen960/startup/intrtbl.h, rxgen960/startup/kkprintf.c,
rxgen960/startup/linkcmds, rxgen960/startup/linkcmds.real,
rxgen960/startup/main.h, rxgen960/startup/memchnl.h,
rxgen960/startup/nmi.c, rxgen960/startup/nulsystbl.c,
rxgen960/startup/pmc901_memmap.h, rxgen960/startup/prcb.c,
rxgen960/startup/prcb.h, rxgen960/startup/rom.ld,
rxgen960/startup/rom_cntrltbl.c, rxgen960/startup/rom_ibr.c,
rxgen960/startup/rom_ibr.h, rxgen960/startup/rom_prcb.c,
rxgen960/startup/rommon.h, rxgen960/startup/sctns.c,
rxgen960/startup/sctns.h, rxgen960/startup/setvec.c,
rxgen960/startup/systbl.c, rxgen960/startup/systbl.h,
rxgen960/startup/time.h, rxgen960/timer/timer.c,
rxgen960/timer/timerisr.S: Removed.
* clock/ckinit.c, console/concntl.h, console/console.c,
include/bsp.h, startup/bspstart.c, timer/timer.c: Convert to using
c99 fixed size types.
wrapup/Makefile.am. Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove.
* bsp_specs: Sync with other BSPs, fixup missing brace.
* start/Makefile.am: Cosmetics.
* clock/ckinit.c, console/console.c, include/bsp.h, startup/bspstart.c,
startup/exit.c, startup/setvec.c, timer/timer.c, timer/timerisr.S:
URL for license changed.
* console/console.c: Remove NO_BSP_INIT, SERIAL_INPUT.
Fixed typo.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am,
start/Makefile.am: Include compile.am
converted to automake.
that converts the i960 directory to automake.
The same kind of libbsp configuration as for the mips64orion, now for
the i960.
In addition to libbsp configuration this patch also contains two fixes
for cvme961.cfg and rxgen960.cfg, which contained non-functional
make-exes. (Now both bsps probably have the same issues with linking c++
applications as the gensh2 has, but this is a different open issue not
tried to be solved now).
The rxgen961 also seems to have problems with its start file, because
linking apps fails due to not finding start.o. (Note that
libbsp/i960/rxgen960 lacks a start subdirectory!). I leave solving this
issue to you :)
autoconf/automake changes.
<mark@ramix.com> of RAMIX.
