* .cvsignore, ChangeLog, Makefile.am, acinclude.m4, configure.ac,
cvme961/.cvsignore, cvme961/ChangeLog, cvme961/Makefile.am,
cvme961/bsp_specs, cvme961/configure.ac, cvme961/times,
cvme961/clock/ckinit.c, cvme961/console/console.c,
cvme961/include/.cvsignore, cvme961/include/bsp.h,
cvme961/include/tm27.h, cvme961/shmsupp/addrconv.c,
cvme961/shmsupp/getcfg.c, cvme961/shmsupp/lock.c,
cvme961/shmsupp/mpisr.c, cvme961/start/start.S,
cvme961/startup/bspclean.c, cvme961/startup/bspstart.c,
cvme961/startup/exit.c, cvme961/startup/linkcmds,
cvme961/startup/setvec.c, cvme961/timer/timer.c,
cvme961/timer/timerisr.S, i960sim/.cvsignore, i960sim/ChangeLog,
i960sim/Makefile.am, i960sim/bsp_specs, i960sim/configure.ac,
i960sim/clock/clockdrv.c, i960sim/console/console-io.c,
i960sim/console/mon-syscalls.S, i960sim/include/.cvsignore,
i960sim/include/bsp.h, i960sim/include/tm27.h, i960sim/start/start.c,
i960sim/startup/bspstart.c, i960sim/startup/linkcmds,
rxgen960/.cvsignore, rxgen960/ChangeLog, rxgen960/Makefile.am,
rxgen960/README, rxgen960/bsp_specs, rxgen960/configure.ac,
rxgen960/clock/ckinit.c, rxgen960/console/concntl.h,
rxgen960/console/console.c, rxgen960/console/serial.c,
rxgen960/console/serial.h, rxgen960/include/.cvsignore,
rxgen960/include/bsp.h, rxgen960/include/rxgen960_config.h,
rxgen960/include/tm27.h, rxgen960/start/rxgen_romld.S,
rxgen960/startup/asmfault.S, rxgen960/startup/asmfault.h,
rxgen960/startup/asmstub.S, rxgen960/startup/asmstub.h,
rxgen960/startup/bspstart.c, rxgen960/startup/cntrltbl.c,
rxgen960/startup/cntrltbl.h, rxgen960/startup/dram.ld,
rxgen960/startup/exit.c, rxgen960/startup/fault.c,
rxgen960/startup/fault.h, rxgen960/startup/faultret.h,
rxgen960/startup/flttbl.c, rxgen960/startup/flttbl.h,
rxgen960/startup/frmstr.c, rxgen960/startup/frmstr.h,
rxgen960/startup/i960.h, rxgen960/startup/ihandler.S,
rxgen960/startup/ihandler.h, rxgen960/startup/intrtbl.c,
rxgen960/startup/intrtbl.h, rxgen960/startup/kkprintf.c,
rxgen960/startup/linkcmds, rxgen960/startup/linkcmds.real,
rxgen960/startup/main.h, rxgen960/startup/memchnl.h,
rxgen960/startup/nmi.c, rxgen960/startup/nulsystbl.c,
rxgen960/startup/pmc901_memmap.h, rxgen960/startup/prcb.c,
rxgen960/startup/prcb.h, rxgen960/startup/rom.ld,
rxgen960/startup/rom_cntrltbl.c, rxgen960/startup/rom_ibr.c,
rxgen960/startup/rom_ibr.h, rxgen960/startup/rom_prcb.c,
rxgen960/startup/rommon.h, rxgen960/startup/sctns.c,
rxgen960/startup/sctns.h, rxgen960/startup/setvec.c,
rxgen960/startup/systbl.c, rxgen960/startup/systbl.h,
rxgen960/startup/time.h, rxgen960/timer/timer.c,
rxgen960/timer/timerisr.S: Removed.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* startup/bspstart.c: Convert to using c99 fixed size types.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Fix minor bugs in previous patch.
wrapup/Makefile.am. Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
* wrapup/Makefile.am: Reflect changes to libcpu.
* start/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* startup/Makefile.am: Ditto.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* bsp_specs: Remove *lib:.
* console/console-io.c, include/bsp.h, startup/bspstart.c: URL for
license changed.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
