* .cvsignore, ChangeLog, Makefile.am, acinclude.m4, configure.ac,
cvme961/.cvsignore, cvme961/ChangeLog, cvme961/Makefile.am,
cvme961/bsp_specs, cvme961/configure.ac, cvme961/times,
cvme961/clock/ckinit.c, cvme961/console/console.c,
cvme961/include/.cvsignore, cvme961/include/bsp.h,
cvme961/include/tm27.h, cvme961/shmsupp/addrconv.c,
cvme961/shmsupp/getcfg.c, cvme961/shmsupp/lock.c,
cvme961/shmsupp/mpisr.c, cvme961/start/start.S,
cvme961/startup/bspclean.c, cvme961/startup/bspstart.c,
cvme961/startup/exit.c, cvme961/startup/linkcmds,
cvme961/startup/setvec.c, cvme961/timer/timer.c,
cvme961/timer/timerisr.S, i960sim/.cvsignore, i960sim/ChangeLog,
i960sim/Makefile.am, i960sim/bsp_specs, i960sim/configure.ac,
i960sim/clock/clockdrv.c, i960sim/console/console-io.c,
i960sim/console/mon-syscalls.S, i960sim/include/.cvsignore,
i960sim/include/bsp.h, i960sim/include/tm27.h, i960sim/start/start.c,
i960sim/startup/bspstart.c, i960sim/startup/linkcmds,
rxgen960/.cvsignore, rxgen960/ChangeLog, rxgen960/Makefile.am,
rxgen960/README, rxgen960/bsp_specs, rxgen960/configure.ac,
rxgen960/clock/ckinit.c, rxgen960/console/concntl.h,
rxgen960/console/console.c, rxgen960/console/serial.c,
rxgen960/console/serial.h, rxgen960/include/.cvsignore,
rxgen960/include/bsp.h, rxgen960/include/rxgen960_config.h,
rxgen960/include/tm27.h, rxgen960/start/rxgen_romld.S,
rxgen960/startup/asmfault.S, rxgen960/startup/asmfault.h,
rxgen960/startup/asmstub.S, rxgen960/startup/asmstub.h,
rxgen960/startup/bspstart.c, rxgen960/startup/cntrltbl.c,
rxgen960/startup/cntrltbl.h, rxgen960/startup/dram.ld,
rxgen960/startup/exit.c, rxgen960/startup/fault.c,
rxgen960/startup/fault.h, rxgen960/startup/faultret.h,
rxgen960/startup/flttbl.c, rxgen960/startup/flttbl.h,
rxgen960/startup/frmstr.c, rxgen960/startup/frmstr.h,
rxgen960/startup/i960.h, rxgen960/startup/ihandler.S,
rxgen960/startup/ihandler.h, rxgen960/startup/intrtbl.c,
rxgen960/startup/intrtbl.h, rxgen960/startup/kkprintf.c,
rxgen960/startup/linkcmds, rxgen960/startup/linkcmds.real,
rxgen960/startup/main.h, rxgen960/startup/memchnl.h,
rxgen960/startup/nmi.c, rxgen960/startup/nulsystbl.c,
rxgen960/startup/pmc901_memmap.h, rxgen960/startup/prcb.c,
rxgen960/startup/prcb.h, rxgen960/startup/rom.ld,
rxgen960/startup/rom_cntrltbl.c, rxgen960/startup/rom_ibr.c,
rxgen960/startup/rom_ibr.h, rxgen960/startup/rom_prcb.c,
rxgen960/startup/rommon.h, rxgen960/startup/sctns.c,
rxgen960/startup/sctns.h, rxgen960/startup/setvec.c,
rxgen960/startup/systbl.c, rxgen960/startup/systbl.h,
rxgen960/startup/time.h, rxgen960/timer/timer.c,
rxgen960/timer/timerisr.S: Removed.
* clock/ckinit.c, include/bsp.h, shmsupp/addrconv.c,
shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c,
startup/bspstart.c, timer/timer.c: Convert to using c99 fixed size
types.
shmsupp/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules.
wrapup/Makefile.am: Remove.
* shmsupp/Makefile.am: Cosmetics.
* shmsupp/Makefile.am: Remove all-local: $(ARCH).
* clock/ckinit.c, console/console.c, include/bsp.h, shmsupp/addrconv.c,
shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c, start/start.S,
startup/bspclean.c, startup/bspstart.c, startup/exit.c,
startup/linkcmds, startup/setvec.c, timer/timer.c, timer/timerisr.S:
URL for license changed.
shmsupp/Makefile.am: Reflect having moved automake.
* shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
converted to automake.
that converts the i960 directory to automake.
The same kind of libbsp configuration as for the mips64orion, now for
the i960.
In addition to libbsp configuration this patch also contains two fixes
for cvme961.cfg and rxgen960.cfg, which contained non-functional
make-exes. (Now both bsps probably have the same issues with linking c++
applications as the gensh2 has, but this is a different open issue not
tried to be solved now).
The rxgen961 also seems to have problems with its start file, because
linking apps fails due to not finding start.o. (Note that
libbsp/i960/rxgen960 lacks a start subdirectory!). I leave solving this
issue to you :)
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
be resolved.
like signal dispatching.
