* configure.ac: Remove RTEMS_CANONICAL_TARGET_CPU.
* Makefile.am: Merge-in debug_ada/Makefile.am, debug_c/Makefile.am,
dos_sup/Makefile.am, network_ada/adasockets/Makefile.am,
network_ada/Makefile.am, network_ada/listener/Makefile.am,
network_ada/tcprelay/Makefile.am, ts_1325_ada/Makefile.am. Use automake
compilation rules.
* debug_ada/Makefile.am, debug_c/Makefile.am, dos_sup/Makefile.am,
network_ada/adasockets/Makefile.am, network_ada/Makefile.am,
network_ada/listener/Makefile.am, network_ada/tcprelay/Makefile.am,
ts_1325_ada/Makefile.am: Remove.
* configure.ac: Remove duplicate
AC_CONFIG_FILES(ts_1325_ada/Makefile).
* debug_ada/Makefile.am: Remove AUTOMAKE_OPTIONS.
* debug_c/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dos_sup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* network_ada/adasockets/Makefile.am: Remove AUTOMAKE_OPTIONS.
* network_ada/Makefile.am: Remove AUTOMAKE_OPTIONS.
* network_ada/listener/Makefile.am: Remove AUTOMAKE_OPTIONS.
* network_ada/tcprelay/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ts_1325_ada/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.in: Remove.
