* configure.ac: Remove RTEMS_CANONICAL_TARGET_CPU.
* debug_ada/cmds, debug_c/cmds: Remove RDBG.
* network_ada/adasockets/AUTHORS,
network_ada/adasockets/sockets-link.ads,
network_ada/adasockets/sockets-multicast.adb,
network_ada/adasockets/sockets-multicast.ads,
network_ada/adasockets/sockets-utils.adb,
network_ada/adasockets/sockets-utils.ads,
network_ada/adasockets/sockets.adb,
network_ada/adasockets/sockets.ads,
network_ada/listener/listener.adb,
network_ada/tcprelay/tcprelay.adb: Convert to utf-8.
* Makefile.am: Merge-in debug_ada/Makefile.am, debug_c/Makefile.am,
dos_sup/Makefile.am, network_ada/adasockets/Makefile.am,
network_ada/Makefile.am, network_ada/listener/Makefile.am,
network_ada/tcprelay/Makefile.am, ts_1325_ada/Makefile.am. Use automake
compilation rules.
* debug_ada/Makefile.am, debug_c/Makefile.am, dos_sup/Makefile.am,
network_ada/adasockets/Makefile.am, network_ada/Makefile.am,
network_ada/listener/Makefile.am, network_ada/tcprelay/Makefile.am,
ts_1325_ada/Makefile.am: Remove.
* Makefile.am: Cosmetics.
* debug_ada/Makefile.am: Cosmetics.
* debug_c/Makefile.am: Cosmetics.
* dos_sup/Makefile.am: Cosmetics.
* network_ada/Makefile.am: Cosmetics.
* network_ada/adasockets/Makefile.am: Cosmetics.
* network_ada/listener/Makefile.am: Cosmetics.
* network_ada/tcprelay/Makefile.am: Cosmetics.
* ts_1325_ada/Makefile.am: Cosmetics.
debug_ada/Makefile.am: Reflect having moved automake.
debug_c/Makefile.am: Reflect having moved automake.
dos_sup/Makefile.am: Reflect having moved automake.
network_ada/Makefile.am: Reflect having moved automake.
network_ada/adasockets/Makefile.am: Reflect having moved automake.
network_ada/listener/Makefile.am: Reflect having moved automake.
network_ada/tcprelay/Makefile.am: Reflect having moved automake.
ts_1325_ada/Makefile.am: Reflect having moved automake.
* configure.ac: Remove duplicate
AC_CONFIG_FILES(ts_1325_ada/Makefile).
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* debug_ada/Makefile.am: Remove AUTOMAKE_OPTIONS.
* debug_c/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dos_sup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* network_ada/adasockets/Makefile.am: Remove AUTOMAKE_OPTIONS.
* network_ada/Makefile.am: Remove AUTOMAKE_OPTIONS.
* network_ada/listener/Makefile.am: Remove AUTOMAKE_OPTIONS.
* network_ada/tcprelay/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ts_1325_ada/Makefile.am: Remove AUTOMAKE_OPTIONS.
* debug_ada/init.c, network_ada/listener/init.c,
network_ada/tcprelay/init.c, ts_1325_ada/init.c: Fixed typo.
* configure.in: Remove.
* configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros.
