Update #3285.
This header is used also by the motorola_powerpc BSP.
Update #3254.
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
* 3c509/3c509.c, clock/ckinit.c, console/console.c, console/fb_vga.c,
console/inch.c, console/ps2_mouse.c, console/serial_mouse.c,
ne2000/ne2000.c, timer/timer.c, wd8003/wd8003.c: Moved irq.h to bsp
subdirectory.
* 3c509/3c509.c, ne2000/ne2000.c: Modified parameters to
remove warnings.
* console/console.c, wd8003/wd8003.c: Added support for
addition of parameter in ISRs.
* 3c509/3c509.c, wd8003/wd8003.c: Eliminate warnings.
* pc386/console/vgainit.c, pc386/wd8003/wd8003.c, shared/comm/uart.c:
Fix errors caught by gcc 4.x.
* ne2000/ne2000.c, wd8003/wd8003.c: Include errno.h as a consequence of
recent updates to BSD header files.
* console/Makefile.am: Add $(PROJECT_INCLUDE)/rtems to
PREINSTALL_FILES.
* console/mouse_parser.c: Include <string.h> (for strcmp).
* console/vt.c: Include <string.h> (for memcpy).
* wd8003/wd8003.c: Include <string.h> (for memcpy, memset).
* include/wd80x3.h: Added file header and logic to prevent multiple
inclusions of this file.
* wd8003/wd8003.c: Corrected attach to include "int attach" parameter.
