Update #3285.
This header is used also by the motorola_powerpc BSP.
Update #3254.
more available on i386.
This change is required to build RTEMS with classic "--enable-networking"
and link applications/tests which reference RTEMS_BSP_NETWORK_DRIVER_ATTACH.
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
* ne2000/ne2000.c: Remove unused var "stat".
PR 1833/bsps
* ne2000/ne2000.c: Addition of multicast support disabled broadcast
reception. Patch also includes support to work on big endian CPUs.
* ne2000/ne2000.c: Add multicast support. Patch submitted to mailing
list 2005-12-21.
* clock/rtc.c, console/console.c, console/inch.c, console/outch.c,
include/bsp.h, include/crt.h, ne2000/ne2000.c, startup/bspcmdline.c,
startup/bspstart.c, startup/ldsegs.S, timer/timer.c,
timer/timerisr.S: Fix typo where license said found in found in.
* ne2000/ne2000.c: Logic on defaulting port number was inverted when
adding command line arguments.
* ne2000/ne2000.c: Add --ne2k-irq and --ne2k-port boot command
line configure options.
* ide/ide.c: Fix a bug which left 4 words in the buffer of the
disk. Some devices do not follow the standard and terminate the
command which a new command occurs and/or low data ready when data
is still to be read.
* clock/ckinit.c, console/serial_mouse.c, ne2000/ne2000.c,
startup/bspstart.c: Fix warnings for prototypes, types, etc.
* ne2000/ne2000.c: Fix spelling error.
* ne2000/ne2000.c (ne_interrupt_handler): Avoid warning.
* ne2000/ne2000.c: Remove typecast.
PR 813/networking
* ne2000/ne2000.c: The ne2000 driver on pc386 has been broken since a
parameter was added to irq handlers (2005-04-18). Before these
changes the argument to the interrupt handler was the interrupt
number, now the argument is handle, but the ne2000 driver needs the
interrupt number. The fix is to set the handle to the interrupt
number.
* 3c509/3c509.c, clock/ckinit.c, console/console.c, console/fb_vga.c,
console/inch.c, console/ps2_mouse.c, console/serial_mouse.c,
ne2000/ne2000.c, timer/timer.c, wd8003/wd8003.c: Moved irq.h to bsp
subdirectory.
* 3c509/3c509.c, ne2000/ne2000.c: Modified parameters to
remove warnings.
* console/console.c, wd8003/wd8003.c: Added support for
addition of parameter in ISRs.
* ne2000/ne2000.c, wd8003/wd8003.c: Include errno.h as a consequence of
recent updates to BSD header files.
* Makefile.am: Merge-in 3c509/Makefile.am, clock/Makefile.am,
console/Makefile.am, ide/Makefile.am, ne2000/Makefile.am,
startup/Makefile.am, timer/Makefile.am, wd8003/Makefile.am,
wrapup/Makefile.am. Use automake compilation rules.
* 3c509/Makefile.am, clock/Makefile.am, console/Makefile.am,
ide/Makefile.am, ne2000/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wd8003/Makefile.am, wrapup/Makefile.am: Remove.
* start/start.S: Change comment to make it gcc -ansi compliant.
* 3c509/Makefile.am: Cosmetics.
* console/Makefile.am: Add preinstallation dirstamp support.
* ide/Makefile.am: Cosmetics.
* ne2000/Makefile.am: Cosmetics.
* start/Makefile.am: Add compilation dirstamp support.
* wd8003/Makefile.am: Cosmetics.
* 3c509/Makefile.am: Remove all-local: $(ARCH).
* ide/Makefile.am: Remove all-local: $(ARCH).
* ne2000/Makefile.am: Remove all-local: $(ARCH).
* wd8003/Makefile.am: Remove all-local: $(ARCH).
* clock/ckinit.c, clock/rtc.c, console/console.c, console/inch.c,
console/outch.c, ide/ide.c, include/bsp.h, include/crt.h,
ne2000/ne2000.c, start/start.S, startup/bspstart.c, startup/exit.c,
startup/ldsegs.S, startup/linkcmds, timer/timer.c, timer/timerisr.S:
URL for license changed.
3c509/Makefile.am: Reflect having moved automake.
ide/Makefile.am: Reflect having moved automake.
ne2000/Makefile.am: Reflect having moved automake.
wd8003/Makefile.am: Reflect having moved automake.
* 3c509/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ne2000/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* wd8003/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* 3c509/Makefile.am: Use .$(OBJEXT) instead of .o.
* ne2000/Makefile.am: Use .$(OBJEXT) instead of .o.
* wd8003/Makefile.am: Use .$(OBJEXT) instead of .o.
* 3c509/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ne2000/Makefile.am: Remove AUTOMAKE_OPTIONS.
* wd8003/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ne2000/ne2000.c: Remove #define __INSIDE_RTEMS_BSD_TCPIP_STACK__.
* ne2000/ne2000.c: Fix some errors in the driver.
1. There was no sufficient check of data in ethernet header.
The code in ne_rx_daemon() was:
inport_word (dport, len);
len -= 4;
if (len > 0)
ne_read_data (sc, startaddr, len, p);
Unfortunately, sometimes my NIC gave me too big len value,
the result was memory override. To fix this, I added ethernet
header data checking.
2. The way overrides were serviced was not good. It was complex
but sometimes did not provide reliable continuing of NIC working.
I had the situation of an endless loop in ne_check_status()
after override processing.
3. There was conceptual error of porting. The old method of
overrides curing was ported from the OS-s, where override-processing
did start immediately. But RTEMS-version uses events, and cleaning
of the overrides can start later.
I selected the way of ne2000 programming that is used
in freebsd kernel (v4.0).
Because of both problems, incorrect data in header of raw packet
and receiver override, it went through ne_reset() and fully
reset the ne2000.
So, in summary
- added detecting of the incorrect data in ethernet header;
- replaced handling of receiver overrides with new scheme,
via resetting of NIC, this method is used also in case of
invalid header detecting.
ne2000/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wd8003/Makefile.am, wrapup/Makefile.am: Include
compile.am
converted to automake.
that converts the libbsp/i386 subdirectory to full automake.
that converts the i386 directory to automake.
NOTE: Ralf is unable to build any i386 BSPs. This was true before and
after this patch and appears (to Joel) to be a tool issue unrelated since
others can build i386 BSPs.
dependencies of "Makefile".
--enable-maintainer-mode.
I added __INSIDE_RTEMS_BSD_TCPIP_STACK__ that trips all the needed
macro definitions for a network driver.
future.
cd <rtems-source-tree>
register support to this driver.
