Update #3285.
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
The name suggests that this is a private implementation header file.
Update #3254.
The BSP_output_char should output a char and not mingle with high level
processing, e.g. '\n' to '\r\n' translation. Move this translation to
rtems_putc(). Remove it from all the BSP_output_char implementations.
Close #3122.
Update #2132.
Intel has obsoleted this hardware and the BSP was never completed.
closes #3086.
Use the BAR to determine IO and memory mapped support for PCI UART
boards.
Move the gdb stub from the i386 UART code to use the libchip drivers.
Use any ports discovered during the probes.
Add gdb control to the boot command line.
Change the device naming to the full device path, not a partial path.
For example /dev/com1.
suppress GCC 6 warning.
closes #2634
This patch adds the "--printk=" boot command line argument to specify
the printk() device. It also enhances the "--console=" boot command
line argument to match any device configured in the console device
table. The arguments are parsed as early as possible so they take
effect early. Currently, this is immediately after PCI initialization.
closes #2364.
driver is not initialized by default
initialization is possible through multiboot command line option or
through the string variable (see fb_default_mode.h) set in user's module
allowing the driver to evaluate this variable after the two
modules are linked together
The current support for the Edison supports a single polled
UART for input and output plus a simulated clock tick. The
activities forward for supporting the Edison have been posted
on the RTEMS mailing lists and at:
http://rtemsramblings.blogspot.com/2014/12/intel-edison-and-rtems-road-forward.html
This allows the support for the legacy COM1-COM4 serial ports
to be completely disabled. It is needed to prevent hangs on some
hardware. In particular, the Intel Edison where it is not present.
This allows the VGA and keyboard console to be completely disabled.
It is useful on PCs without displays and prevents a very slow boot
time on the Intel Edison.
structs, break >80 chars lines, removed newlines at EOFs
fb_vesa_rm.c: removed inline from functions declared in fb_vesa.h
removed unnecessary printks in the end of patch
edid.h, vbe3.h: switched from custom *PACKED_ATTRIBUTE at the structs to the
RTEMS_COMPILER_PACKED_ATTRIBUTE for easier maintainability
of doxygen
Implementation is tested to work on QEMU simulator only.
QEMU offers this hardware by default for PC platform but
it can be requested by "-vga cirrus" option for other PCI
aware systems in development/next QEMU releases as well.
Next sources have been used for driver implementation:
- RTEMS fb_vga.c - Rosimildo da Silva ( rdasilva@connecttel.com )
- Cirrus xf86 driver - used as VGA hardware setup documentation
- CL-GD5446 Technical Reference Manual, 1996, Second Edition
fb_vga.c has to be replaced by fb_cirrus.c in
rtems/c/src/lib/libbsp/i386/pc386/Makefile.am
to test the driver now. We expect to discus and include driver
section mechanism after driver testing.
Patch version 2:
- comments style updated according to Joel Sherrill review
- use static for variables and functions to compile without warnings
Signed-off-by: Alexandru-Sever Horin <alex.sever.h@gmail.com>
Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
- RTD316 is a PC-104 board with one Z85C30 SCC for two synchronous
or asynchronous serial ports.
http://www.rtd.com/PC104/UM/network/CM316HR.htm
- Exar 17D15X is a chip with 2, 4, or 8 NS16550 compatible
serial ports with a PCI interface. It may be found on
many multi-port serial ports including:
http://www.rtd.com/PC104/UM/network/CM17320HR.htm
This was broken by conversion of console driver to libchip style.
* console/vt.c: Make _kd_mksound static.
* ide/ide.c: Make pc386_ide_probe, pc386_ide_initialize,
pc386_ide_read_reg, pc386_ide_write_reg, pc386_ide_write_block,
pc386_ide_control, pc386_ide_config_io_speed static.
* console/vgacons.c: Add VGACONS_STATIC.
* console/vgacons.h: Remove VGACONS_STATIC.
PR 1925
* Makefile.am, preinstall.am, console/serial_mouse_config.c,
include/bsp.h, start/start.S: Converted 1386 console to the libchip
style console
* console/conscfg.c, console/console_control.c,
console/printk_support.c, console/vgacons.c, console/vgacons.h: New
files.
