Update #3285.
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
* pc386/3c509/3c509.c, pc386/console/ps2_drv.h,
pc386/console/serial_mouse.c, pc386/console/serial_mouse.h:
Remove CVS Headers.
* 3c509/3c509.c: Remove [$]Log.
Include <errno.h> instead of <sys/errno.h>.
* 3c509/3c509.c, clock/ckinit.c, console/console.c, console/fb_vga.c,
console/inch.c, console/ps2_mouse.c, console/serial_mouse.c,
ne2000/ne2000.c, timer/timer.c, wd8003/wd8003.c: Moved irq.h to bsp
subdirectory.
* 3c509/3c509.c, ne2000/ne2000.c: Modified parameters to
remove warnings.
* console/console.c, wd8003/wd8003.c: Added support for
addition of parameter in ISRs.
* 3c509/3c509.c, wd8003/wd8003.c: Eliminate warnings.
* 3c509/3c509.c: Add <sys/errno.h>.
* startup/linkcmds: Add .jcr section.
