network/Makefile.am, startup/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove.
* network/Makefile.am: Cosmetics.
* wrapup/Makefile.am: Cosmetics
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
location in libc.
converted to automake.
that converts the libbsp/i386 subdirectory to full automake.
