Close #3250.
Close #4081.
system. Since all content of
makes no sense to keep it.
Update #3285.
upgrade to that version.
Close #3387.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
* Makefile.am: Merge-in shared/Makefile.am.
* ChangeLog: Merge-in shared/ChangeLog.
* configure.ac: Remove shared/Makefile.am.
* configure.ac: RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY]).
* configure.ac: Remove shared/io/Makefile, shared/comm/Makefile,
shared/pci/Makefile, shared/irq/Makefile.
* acinclude.m4: Reflect changes to bootstrap.
* configure.ac: Remove RTEMS_CHECK_CUSTON_BSP.
* configure.in: Remove.
