converted to automake.
that converts the hppa1.1 directory to automake.
NOTE:
* Due to not having a toolchain (gcc refuses to build) this patch is
untested.
* I omited/deactivated the pxfl subdirectory, because I don't
understand how it supposed to work.
Joel's note: It was right to ignore the pxfl directory. It should be
removed one the BSPs are moved outside the tree. This was an old hack.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
to lib/include.
be resolved.
