* | Remove. | Ralf Corsepius | 2005-10-16 | 1 | -13/+0 |
* | Port of RTEMS to the Texas Instruments C3x/C4x DSP families including | Joel Sherrill | 2000-07-26 | 1 | -0/+13 |
a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4. |
