This reverts commit dbe85952f9adac28a2dc84473eac24ae2c85e260.
Accidentally merged.
warning and clean up
not updated.
Sorting removed the variations across different host operating systems
and file systems.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
Conflicts:
* Makefile.am: Remove reference to non-existing file times.
* console/console.c: Now compiles.
* acinclude.m4: Regenerated for TLL6527M.
* console/console-io.c: Regenerated for TLL6527M.
PR 1781/bsps
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, times, console/console.c, include/bsp.h,
include/cplb.h, include/tm27.h, make/custom/TLL6527M.cfg,
startup/bspstart.c, startup/linkcmds: New files.
Initial port for the TLL6527Mboard that contains blackfin 52X
range of processors. Used eZKit533 as a reference for building
the port.
PR 1781/bsps
* console/console-io.c: The UART RX and TX are different ISR
now. So the array containing the registeration changes. The
change is due to change in the libcup uart function.
* ChangeLog, shared/start/start.S: Add HLT instruction on exit.
* ChangeLog, start/start.S: Add HLT instruction on exit.
* include/tm27.h, startup/bspstart.c:
* startup/bspstart.c:
* Makefile.am: Do not use .rel files for libbsp pieces.
* shared/start/start.S: Pass 0/NULL for argc/argv.
PR 1488/bsps
* start/start.S: Micromon on bf537 uses DMA for UART reception.
This prevents the UART driver in RTEMS from working (and also
causes received characters to be stored in a buffer that RTEMS
doesn't know about, so it's potentially dangerous, but in practice
the risk is small since an RTEMS app intended to be booted from
Micromon would normally be configured to leave the RAM Micromon
uses reserved). The attached patch corrects this by disabling
all DMA channels at startup.
* console/console-io.c: Let bf537Stamp_BSP_poll_char return int.
* console/console-io.c: Let eZKit533_BSP_poll_char return int.
* make/custom/eZKit533.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/bf537Stamp.cfg: Remove RTEMS_BSP_FAMILY.
