Close #3250.
Close #4081.
system. Since all content of
makes no sense to keep it.
Update #3285.
Update #3387.
upgrade to that version.
Close #3387.
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Updates #3250.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* configure.ac: Add BFIN_ON_SKYEYE define to disable features not
supported on simulator.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* Makefile.am, configure.ac, startup/bspstart.c, startup/linkcmds:
Split out bsp_get_work_area() into its own file and user BSP
Framework to perform more initialization.
* configure.ac, eZKit533/configure.ac, eZKit533/include/bsp.h,
shared/start/start.S: Make use of separated bfin helper .h files.
* bfin/ChangeLog, bfin/Makefile.am, bfin/acinclude.m4,
bfin/configure.ac, bfin/eZKit533/.cvsignore, bfin/eZKit533/ChangeLog,
bfin/eZKit533/Makefile.am, bfin/eZKit533/README,
bfin/eZKit533/bsp_specs, bfin/eZKit533/configure,
bfin/eZKit533/configure.ac, bfin/eZKit533/preinstall.am,
bfin/eZKit533/times, bfin/eZKit533/console/console-io.c,
bfin/eZKit533/include/.cvsignore, bfin/eZKit533/include/bsp.h,
bfin/eZKit533/include/bspopts.h.in, bfin/eZKit533/include/coverhd.h,
bfin/eZKit533/include/tm27.h, bfin/eZKit533/startup/bspstart.c,
bfin/eZKit533/startup/linkcmds, bfin/shared/clock/clockdrv.c,
bfin/shared/clock/rtc.c, bfin/shared/clock/tod.h,
bfin/shared/console/console.c, bfin/shared/start/start.S,
bfin/shared/timer/timer.c: New files.
