Update #3285.
warnings
* console/console.c: Now compiles.
PR 1781/bsps
* console/console-io.c: The UART RX and TX are different ISR
now. So the array containing the registeration changes. The
change is due to change in the libcup uart function.
* console/console-io.c: Let bf537Stamp_BSP_poll_char return int.
* configure.ac, console/console.c: Add BFIN_ON_SKYEYE define to disable
features not supported on simulator.
* configure.ac, console/console.c: Add skyeye alias for bf537stamp.
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, console/console.c, include/bsp.h,
network/networkconfig.c, start/start.S, startup/bspstart.c,
startup/linkcmds: New files.
