* | build: Remove old build system | Sebastian Huber | 2021-09-21 | 1 | -89/+0 |
| | | | | | Close #3250. Close #4081. | ||||
* | bsps/xilinx_zynq: Add Xilinx AXI SPI driver to autotools build | Jan Sommer | 2021-03-30 | 1 | -0/+1 |
| | | | | Closes #4321 | ||||
* | bsps/xilinx_zynq: Add SPI driver to autotools build | Jan Sommer | 2021-03-10 | 1 | -0/+3 |
| | | | | Closes #4320 | ||||
* | bsps: Add default rtems_get_target_hash() | Sebastian Huber | 2021-02-26 | 1 | -0/+1 |
| | | | | Update #4267. | ||||
* | bsps: Use header file for GIC architecture support | Sebastian Huber | 2020-12-23 | 1 | -1/+0 |
| | | | | | | This avoids a function call overhead in the interrupt dispatching. Update #4202. | ||||
* | bsps: Move ARM GICv2 driver to bsps/shared | Kinsey Moore | 2020-12-02 | 1 | -1/+2 |
| | | | | | This moves the ARM GICv2 driver to bsps/shared to be usable by AArch64 code. | ||||
* | bsps: Move zynq-uart to bsps/shared | Kinsey Moore | 2020-12-02 | 1 | -2/+2 |
| | | | | | This moves the zynq-uart driver from bsps/arm/shared to bsps/shared to accomodate use by AArch64 BSPs. | ||||
* | bsps: Break out AArch32 portions of GPT driver | Kinsey Moore | 2020-10-05 | 1 | -1/+2 |
| | | | | | | This breaks AArch32-specific portions of the ARM GPT driver into their own file so that the generic code can be moved for reuse by other architectures. | ||||
* | arm/xilinx-zynq: Split console driver files | Sebastian Huber | 2020-02-12 | 1 | -0/+1 |
| | | | | | This avoids to pull in via printk() the Termios support which pulls in the file system support. This fixes a spconfig02 test failure. | ||||
* | bsp/xilinx-zynqmp: Implement Ultra96 target | Jeff Kubascik | 2019-04-11 | 1 | -15/+11 |
| | | | | | | Modifications to get xilinx-zynqmp BSP working on an Ultra96 board. Update #3682. | ||||
* | bsp/xilinx-zynqmp: Stub out Xilinx MPSoC BSP | Jeff Kubascik | 2019-04-11 | 1 | -0/+86 |
Source files were copied from xilinx-zynq. Update #3682. |
