* | bsps: Move console drivers to bsps | Sebastian Huber | 2018-04-20 | 1 | -315/+0 |
| | | | | | | This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | bsp/xilinx-zynq: Add interrupt support to UART | Sebastian Huber | 2017-02-22 | 1 | -8/+94 |
* | bsp/xilinx-zynq: Use new Termios device driver | Sebastian Huber | 2017-02-21 | 1 | -53/+41 |
* | arm/zynq: Wait for the UART TX FIFO to empty on reset. | Chris Johns | 2016-11-29 | 1 | -0/+13 |
* | bsp/xilinx-zynq: Rename BSP_ARM_A9MPCORE_UARTCLK | Sebastian Huber | 2014-11-20 | 1 | -1/+1 |
| | | | | | Rename BSP_ARM_A9MPCORE_UARTCLK to ZYNQ_CLOCK_UART since this clock has nothing to do with the Cortex-A9 MPCore. | ||||
* | bsps/zynq: Add BSP_ARM_A9MPCORE_UARTCLK to set the UART clock rate. | Chris Johns | 2014-05-22 | 1 | -1/+3 |
| | | | | | This value can be found the xparameters.h file generated by the Xilinx tools. | ||||
* | arm/xilinx__zynq: Support application based clock freq. | Chris Johns | 2013-12-10 | 1 | -2/+110 |
| | | | | | | | Provide a weak call to a clock freq routine to allow the application to supply the freq defined in the Xilinx generated source. Add code to calculate the baud rate. | ||||
* | bsp/xilinx-zynq: Use magic UART baud divisor | Sebastian Huber | 2013-06-19 | 1 | -2/+2 |
| | | | | Use a baud divisor suitable for the evaluation board. | ||||
* | bsp/xilinx-zynq: Do not start transmitter break | Sebastian Huber | 2013-06-19 | 1 | -1/+0 |
* | bsp/xilinx-zynq: New BSP | Sebastian Huber | 2013-05-06 | 1 | -0/+119 |
