path: root/c/src/lib/libbsp/arm/tms570/clock/benchmark_timer.c (follow)
* bsp/tms570: Use shared benchmark timerSebastian Huber2017-03-271-60/+0
* Use correct prototype of benchmark_timer_read()Joel Sherrill2014-09-161-2/+1
| | | | | | | | | | | | | | This change starts with removing the effectively empty file timerdrv.h. The prototypes for benchmark_timer_XXX() were in btimer.h which was not universally used. Thus every use of timerdrv.h had to be changed to btimer.h. Then the prototypes for benchmark_timer_read() had to be adjusted to return benchmark_timer_t rather than int or uint32_t. I took this opportunity to also correct the file headers to separate the copyright from the file description comments which is needed to ensure the copyright isn't propagated into Doxygen output.
* bsp/tms570: implemented support functions to satisfy complete tests build ↵Pavel Pisa2014-08-211-0/+61
requirements. This patch enables to build all RTEMS tests for tms570ls3137_hdk_sdram BSP variant in in default build. Debug build with --enable-rtems-debug set has succeed for samples subset of tests as well.
