* shared/startup/linkcmds.base: Define bsp_vector_table_size
unconditionally. Use bsp_vector_table_in_start_section.
* shared/start/start.S, shared/startup/linkcmds.base,
shared/include/linker-symbols.h: Added and use bsp_vector_table_begin,
bsp_vector_table_size and bsp_vector_table_end.
* shared/include/start.h: Define start section attributes.
* shared/irq_init.c: Removed file.
* Makefile.am: Reflect change above.
added thumb support to start.S
updated documentation
* shared/comm/console.c: Remove (Unused).
* Makefile.am: Remove shared/comm/console.c.
* shared/comm/console.c: Reflect termios_baud_to_number having been
renamed to rtems_termios_baud_to_number.
Added bsp_start_memcpy(). Documentation. Changes for external ROM start.
* shared/start/start.S: Update for boot_card command line change.
PR 1385/cpukit
* shared/irq/irq_asm.S: When the type rtems_boolean was switched to the
C99 bool, the size changed from 4 bytes to 1 byte. The interrupt
dispatching code accesses two boolean variables for scheduling
purposes and the assembly implementations of this code did not get
updated.
* shared/irq/irq_asm.S: Newer compilers handle alignment better.
* Makefile.am, configure.ac, preinstall.am: Added BSP variants.
* console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed
register settings. Cleanup.
* include/bsp.h: Added network defines and functions.
* include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status
sizes.
* include/system-clocks.h, misc/system-clocks.c: Added micro seconds
delay function that uses Timer 1. Changed PLL setup.
* network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478,
startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New
files.
* startup/bspstart.c: Added EMC initialization. Changes for ROM boot.
* acinclude.m4, shared/comm/console.c: Use standardized bsp_cleanup()
which can optionally print a message, poll for user to press key, and
call bsp_reset(). Using this eliminates the various bsp_cleanup()
implementations which had their own implementation and variety of
string constants.
* shared/bspgetworkarea.c: Removed.
* shared/bspgetworkarea.c: New file.
* shared/irq/irq_init.c: Add missing prototypes.
* shared/irq/irq_asm.S: Correct minor mistakes in adding Thumb code
which prevented ARM from working.
* shared/comm/console.c: Eliminate copies of switches to convert
termios Bxxx constants to xxx as an integer. Use the shared
termios_baud_to_number() routine to do the same conversion.
* shared/comm/console.c: Do not have BSP specific __assert.
* shared/abort/simple_abort.c: Add veneer for ARM<->Thumb
shared/irq/irq_asm.S: Add veneer for ARM<->Thumb
PR 1257/bsps
* csb336/network/lan91c11x.c, csb337/startup/bspstart.c,
edb7312/irq/irq.c, gba/irq/irq.c, gba/irq/irq_init.c,
gp32/startup/bspstart.c, rtl22xx/startup/bspstart.c,
shared/abort/abort.c, shared/abort/simple_abort.c,
shared/irq/irq_init.c: Code outside of cpukit should use the public
API for rtems_interrupt_disable/rtems_interrupt_enable. By bypassing
the public API and directly accessing _CPU_ISR_Disable and
_CPU_ISR_Enable, they were bypassing the compiler memory barrier
directive which could lead to problems. This patch also changes the
type of the variable passed into these routines and addresses minor
style issues.
* shared/abort/abort.c, shared/abort/simple_abort.c: Remove incorrect
and unneccessary prototype of printk.
* shared/abort/simple_abort.c: Shrink the memory requirements. Joel
reformatted for style.
* shared/abort/abort.c, shared/abort/simple_abort.c: New files.
* shared/irq/irq_init.c: Changed interrupt handling
to use shared rtems_irq_connect_data struct.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Merge-in comm/Makefile.am, irq/Makefile.am
* comm/Makefile.am: Remove.
* irq/Makefile.am: Remove.
PR 480/bsps
* shared/irq/irq_asm.S: Remove duplicate code.
* comm/console.c, comm/uart.c, comm/uart.h, irq/irq_asm.S,
irq/irq_init.c: URL for license changed.
comm/Makefile.am: Reflect having moved automake.
irq/Makefile.am: Reflect having moved automake.
* irq/irq_asm.S, irq/irq_init.c: Fixes a bug with handling the
situation where we are processing an IRQ, and we receive an FIQ.
