path: root/c/src/lib/libbsp/arm/nds/Makefile.am (follow)
* arm/nds: RemoveAun-Ali Zaidi2015-12-111-236/+0
| | | | updates #2450.
* bsps: Delete superfluous bsp_pretasking_hook()Sebastian Huber2015-12-101-1/+0
| | | | | | Use the bsp_predriver_hook() instead. Update #2408.
* arm/nds: Warning clean upJoel Sherrill2014-10-101-0/+1
| | | | | | This patch eliminates most of the warnings in this BSP but attempts very little clean up. This BSP includes copies of a lot of code from free NDS libraries and modifications should be kept to a minimum.
* nds/Makefile.am: Rework to avoid creating ltos of .rel filesJoel Sherrill2014-08-271-71/+35
| | | | This was necessary to enable all tests to link.
* bsps: Add empty cache managerSebastian Huber2014-02-241-0/+5
| | | | | This is necessary to add tests that use the cache manager. For example to get better estimates of worst-case timings.
* score: Add CPU counter supportSebastian Huber2014-02-141-0/+2
| | | | | | | | | Add a CPU counter interface to allow access to a free-running counter. It is useful to measure short time intervals. This can be used for example to enable profiling of critical low-level functions. Add two busy wait functions rtems_counter_delay_ticks() and rtems_counter_delay_nanoseconds() implemented via the CPU counter.
* Remove CVS-Ids.Ralf Corsépius2012-05-041-4/+0
* 2011-06-19 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-06-191-1/+2
| | | | * Makefile.am: Fix broken path to clockdrv_shell.h.
* 2010-12-03 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-12-031-1/+1
| | | | | | | | | * startup/bspgetworkarea.c: Removed file. * Makefile.am, bsp_specs, start/start.S, startup/bspstart.c, libnds/include/nds/jtypes.h, libnds/source/arm9/gurumeditation.c, libnds/source/common/interruptDispatcher.S, libnds/source/common/interrupts.c, startup/linkcmds: Use linker command base file.
* 2010-04-30 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-04-301-6/+6
| | | | | * make/custom/nds.cfg, Makefile.am, dswifi/arm7/makefile: Use VFP floating point model.
* unify irq data types and code, merge s3c2400/s3c2410 supportThomas Doerfler2010-04-091-2/+0
* 2009-12-07 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-12-071-1/+1
| | | | * Makefile.am: Remove -Dcaddr_t=uint32_t.
* 2009-08-10 Roxana Leontie <roxana.leontie@gmail.com>Joel Sherrill2009-08-101-1/+1
| | | | | | | | * fb/fb.c: function calls renamed; defined references to the extern functions * fb/fb.h: Removed. * Makefile.am: Reflect removal. * preinstall.am: Regenerated.
* 2009-08-10 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-08-101-2/+2
| | | | | * Makefile.am, preinstall.am, fb/fb.c: Install nds specific .h files into nds subdirectory.
* 2009-02-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-02-041-1/+1
| | | | * Makefile.am: Add -D__BSD_VISIBLE to wifi_rel_CPPFLAGS.
* 2008-10-02 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-10-021-1/+1
| | | | | * Makefile.am, preinstall.am: Use shared tm27.h stub. * include/tm27.h: Removed.
* 2008-09-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-301-1/+1
| | | | | * clock/clock.c: include "../../../shared/clockdrv_shell.h". * Makefile.am: Reflect changes above.
* 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-291-6/+4
| | | | | * Makefile.am: Eliminate bsp.am. Build startup files as side-effect of building libbspstart.a, using automake-rules.
* 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-291-1/+1
| | | | * Makefile.am: Eliminate *_SOURCES.
* 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-291-1/+2
| | | | | * Makefile.am: Move noinst_LIBRARIES = libbsp.a before its components.
* 2008-09-26 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-261-0/+3
| | | | * Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* 2008-09-22 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-221-3/+3
| | | | | | | | | * Makefile.am, configure.ac: Use standardized bsp_cleanup() which can optionally print a message, poll for user to press key, and call bsp_reset(). Using this eliminates the various bsp_cleanup() implementations which had their own implementation and variety of string constants. * startup/bspclean.c: Removed.
* 2008-09-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-141-2/+3
| | | | | | | | * Makefile.am, configure.ac: Split out bsp_cleanup() and bsp_get_work_area() into their own files. * startup/bspclean.c, startup/bspgetworkarea.c, startup/bspstart.c: New files. * startup/start.c: Removed.
* 2008-05-20 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-05-201-4/+11
| | | | | * Makefile.am, configure.ac, startup/start.c: Use new framework capability where RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION.
* 2008-04-18 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-04-181-1/+1
| | | | | | * Makefile.am: Use bin2s to produce assembly files which do not need preprocessing. Capital .S indicates an assembly file that gets preprocessed.
* 2008-04-17 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-04-171-9/+9
| | | | | | | | | | | | | | | | | * Makefile.am: Move .s files to .S * dswifi/common/source/spinlock.S, libfat/source/disc_io/io_dldi.S, libfat/source/disc_io/io_scsd_s.S, libnds/source/arm9/COS.S, libnds/source/arm9/SIN.S, libnds/source/arm9/TAN.S, libnds/source/arm9/dcache.S, libnds/source/arm9/default_font.S, libnds/source/arm9/icache.S, libnds/source/common/biosCalls.S, libnds/source/common/interruptDispatcher.S: New files. * dswifi/common/source/spinlock.s, libfat/source/disc_io/io_dldi.s, libfat/source/disc_io/io_scsd_s.s, libnds/source/arm9/COS.s, libnds/source/arm9/SIN.s, libnds/source/arm9/TAN.s, libnds/source/arm9/dcache.s, libnds/source/arm9/default_font.s, libnds/source/arm9/exceptionHandler.s, libnds/source/arm9/icache.s, libnds/source/common/biosCalls.s, libnds/source/common/interruptDispatcher.s: Removed.
* 2008-04-16 Matthieu Bucchianeri <mbucchia@gmail.com>Joel Sherrill2008-04-161-0/+260
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac, mk_libnds.sh, patch.libnds, preinstall.am, block/block.c, clock/clock.c, console/console.c, coproc/coproc.S, coproc/coproc.c, coproc/coproc.ld, dswifi/dswifi_license.txt, dswifi/makefile, dswifi/arm7/makefile, dswifi/arm7/source/wifi_arm7.c, dswifi/arm7/source/wifi_arm7.h, dswifi/arm9/makefile, dswifi/arm9/source/sgIP.c, dswifi/arm9/source/sgIP.h, dswifi/arm9/source/sgIP_ARP.c, dswifi/arm9/source/sgIP_ARP.h, dswifi/arm9/source/sgIP_Config.h, dswifi/arm9/source/sgIP_DHCP.c, dswifi/arm9/source/sgIP_DHCP.h, dswifi/arm9/source/sgIP_DNS.c, dswifi/arm9/source/sgIP_DNS.h, dswifi/arm9/source/sgIP_Hub.c, dswifi/arm9/source/sgIP_Hub.h, dswifi/arm9/source/sgIP_ICMP.c, dswifi/arm9/source/sgIP_ICMP.h, dswifi/arm9/source/sgIP_IP.c, dswifi/arm9/source/sgIP_IP.h, dswifi/arm9/source/sgIP_TCP.c, dswifi/arm9/source/sgIP_TCP.h, dswifi/arm9/source/sgIP_UDP.c, dswifi/arm9/source/sgIP_UDP.h, dswifi/arm9/source/sgIP_memblock.c, dswifi/arm9/source/sgIP_memblock.h, dswifi/arm9/source/sgIP_sockets.c, dswifi/arm9/source/sgIP_sockets.h, dswifi/arm9/source/wifi_arm9.c, dswifi/arm9/source/wifi_arm9.h, dswifi/common/source/dsregs.h, dswifi/common/source/spinlock.h, dswifi/common/source/spinlock.s, dswifi/common/source/wifi_shared.h, dswifi/include/dswifi7.h, dswifi/include/dswifi9.h, dswifi/include/dswifi_version.h, dswifi/include/netdb.h, dswifi/include/sgIP_errno.h, dswifi/include/netinet/in.h, fb/fb.c, fb/fb.h, include/bsp.h, include/my_ipc.h, include/tm27.h, include/types.h, include/sys/iosupport.h, irq/irq.c, irq/irq.h, libfat/gba/include/fat.h, libfat/include/fat.h, libfat/nds/include/fat.h, libfat/source/bit_ops.h, libfat/source/cache.c, libfat/source/cache.h, libfat/source/common.h, libfat/source/directory.c, libfat/source/directory.h, libfat/source/fatdir.c, libfat/source/fatdir.h, libfat/source/fatfile.c, libfat/source/fatfile.h, libfat/source/file_allocation_table.c, libfat/source/file_allocation_table.h, libfat/source/filetime.c, libfat/source/filetime.h, libfat/source/libfat.c, libfat/source/mem_allocate.h, libfat/source/partition.c, libfat/source/partition.h, libfat/source/disc_io/disc.c, libfat/source/disc_io/disc.h, libfat/source/disc_io/disc_io.h, libfat/source/disc_io/io_cf_common.c, libfat/source/disc_io/io_cf_common.h, libfat/source/disc_io/io_dldi.h, libfat/source/disc_io/io_dldi.s, libfat/source/disc_io/io_efa2.c, libfat/source/disc_io/io_efa2.h, libfat/source/disc_io/io_fcsr.c, libfat/source/disc_io/io_fcsr.h, libfat/source/disc_io/io_m3_common.c, libfat/source/disc_io/io_m3_common.h, libfat/source/disc_io/io_m3cf.c, libfat/source/disc_io/io_m3cf.h, libfat/source/disc_io/io_m3sd.c, libfat/source/disc_io/io_m3sd.h, libfat/source/disc_io/io_mpcf.c, libfat/source/disc_io/io_mpcf.h, libfat/source/disc_io/io_njsd.c, libfat/source/disc_io/io_njsd.h, libfat/source/disc_io/io_nmmc.c, libfat/source/disc_io/io_nmmc.h, libfat/source/disc_io/io_sc_common.c, libfat/source/disc_io/io_sc_common.h, libfat/source/disc_io/io_sccf.c, libfat/source/disc_io/io_sccf.h, libfat/source/disc_io/io_scsd.c, libfat/source/disc_io/io_scsd.h, libfat/source/disc_io/io_scsd_s.s, libfat/source/disc_io/io_sd_common.c, libfat/source/disc_io/io_sd_common.h, libnds/Makefile.arm7, libnds/Makefile.arm9, libnds/libnds_license.txt, libnds/basicARM7/source/defaultARM7.c, libnds/include/default_font_bin.h, libnds/include/gbfs.h, libnds/include/nds.h, libnds/include/nds/bios.h, libnds/include/nds/card.h, libnds/include/nds/dma.h, libnds/include/nds/interrupts.h, libnds/include/nds/ipc.h, libnds/include/nds/jtypes.h, libnds/include/nds/memory.h, libnds/include/nds/registers_alt.h, libnds/include/nds/reload.h, libnds/include/nds/system.h, libnds/include/nds/timers.h, libnds/include/nds/arm7/audio.h, libnds/include/nds/arm7/clock.h, libnds/include/nds/arm7/serial.h, libnds/include/nds/arm7/touch.h, libnds/include/nds/arm9/background.h, libnds/include/nds/arm9/boxtest.h, libnds/include/nds/arm9/cache.h, libnds/include/nds/arm9/console.h, libnds/include/nds/arm9/exceptions.h, libnds/include/nds/arm9/image.h, libnds/include/nds/arm9/input.h, libnds/include/nds/arm9/math.h, libnds/include/nds/arm9/ndsmotion.h, libnds/include/nds/arm9/pcx.h, libnds/include/nds/arm9/postest.h, libnds/include/nds/arm9/rumble.h, libnds/include/nds/arm9/sound.h, libnds/include/nds/arm9/sprite.h, libnds/include/nds/arm9/trig_lut.h, libnds/include/nds/arm9/video.h, libnds/include/nds/arm9/videoGL.h, libnds/source/arm7/audio.c, libnds/source/arm7/clock.c, libnds/source/arm7/microphone.c, libnds/source/arm7/spi.c, libnds/source/arm7/touch.c, libnds/source/arm7/userSettings.c, libnds/source/arm9/COS.bin, libnds/source/arm9/COS.s, libnds/source/arm9/SIN.bin, libnds/source/arm9/SIN.s, libnds/source/arm9/TAN.bin, libnds/source/arm9/TAN.s, libnds/source/arm9/boxtest.c, libnds/source/arm9/console.c, libnds/source/arm9/dcache.s, libnds/source/arm9/default_font.bin, libnds/source/arm9/default_font.s, libnds/source/arm9/exceptionHandler.S, libnds/source/arm9/exceptionHandler.s, libnds/source/arm9/exceptions.c, libnds/source/arm9/gurumeditation.c, libnds/source/arm9/icache.s, libnds/source/arm9/image.c, libnds/source/arm9/initSystem.c, libnds/source/arm9/keys.c, libnds/source/arm9/ndsmotion.c, libnds/source/arm9/pcx.c, libnds/source/arm9/rumble.c, libnds/source/arm9/sound.c, libnds/source/arm9/system.c, libnds/source/arm9/touch.c, libnds/source/arm9/video.c, libnds/source/arm9/videoGL.c, libnds/source/common/biosCalls.s, libnds/source/common/card.c, libnds/source/common/gbfs.c, libnds/source/common/interruptDispatcher.s, libnds/source/common/interrupts.c, rtc/rtc.c, sound/sound.c, sound/sound.h, start/start.S, startup/linkcmds, startup/start.c, timer/timer.c, tools/Makefile.am, tools/bin2s, tools/bin2s.c, tools/configure.ac, tools/runtest, tools/ndstool/include/arm7_sha1_homebrew.h, tools/ndstool/include/arm7_sha1_nintendo.h, tools/ndstool/include/banner.h, tools/ndstool/include/bigint.h, tools/ndstool/include/crc.h, tools/ndstool/include/default_icon.h, tools/ndstool/include/encryption.h, tools/ndstool/include/header.h, tools/ndstool/include/hook.h, tools/ndstool/include/little.h, tools/ndstool/include/loadme.h, tools/ndstool/include/logo.h, tools/ndstool/include/ndscreate.h, tools/ndstool/include/ndsextract.h, tools/ndstool/include/ndstool.h, tools/ndstool/include/ndstree.h, tools/ndstool/include/overlay.h, tools/ndstool/include/passme.h, tools/ndstool/include/passme_sram.h, tools/ndstool/include/passme_vhd1.h, tools/ndstool/include/passme_vhd2.h, tools/ndstool/include/raster.h, tools/ndstool/include/sha1.h, tools/ndstool/include/types.h, tools/ndstool/source/arm7_sha1_homebrew.c, tools/ndstool/source/arm7_sha1_nintendo.c, tools/ndstool/source/banner.cpp, tools/ndstool/source/bigint.cpp, tools/ndstool/source/compile_date.c, tools/ndstool/source/crc.cpp, tools/ndstool/source/default_icon.c, tools/ndstool/source/encryption.cpp, tools/ndstool/source/header.cpp, tools/ndstool/source/hook.cpp, tools/ndstool/source/loadme.c, tools/ndstool/source/logo.cpp, tools/ndstool/source/ndscodes.cpp, tools/ndstool/source/ndscreate.cpp, tools/ndstool/source/ndsextract.cpp, tools/ndstool/source/ndstool.cpp, tools/ndstool/source/ndstree.cpp, tools/ndstool/source/passme.cpp, tools/ndstool/source/passme_sram.c, tools/ndstool/source/raster.cpp, tools/ndstool/source/sha1.cpp, touchscreen/README.reco, touchscreen/parser.c, touchscreen/reco.c, touchscreen/reco.h, touchscreen/touchscreen.c, touchscreen/touchscreen.h, wifi/compat.c, wifi/compat.h, wifi/wifi.c: New files.
