* misc/system-clocks.c: New file.
* Makefile.am: Reflect change from above.
* include/nand-mlc.h: Fixed lpc32xx_mlc_is_bad_page().
* make/custom/lpc32xx.inc, make/custom/lpc32xx_mzx_stage_1.cfg: Flags
for EABI tool chain.
* configure.ac, include/bsp.h, include/lpc32xx.h, misc/emc.c,
misc/i2c.c, rtc/rtc-config.c, startup/bspstarthooks.c: Avoid compile
time ARM_CLK and HCLK.
* Makefile.am: Add shared/startup/bsp-start-memcpy.S
PR 1917/bsps
* Makefile.am, console/console-config.c, console/hsu.c: Modifications
to add dynamic tables for libchip serial drivers.
* make/custom/lpc32xx.inc: Workaround for GCC bug 50106.
* include/lpc32xx.h: Fixed register map for NAND MLC.
* include/boot.h: Declare lpc32xx_set_boot_block_bad().
* misc/boot.c: Define lpc32xx_set_boot_block_bad().
* include/nand-mlc.h, misc/nand-mlc-erase-block-safe.c,
misc/nand-mlc-read-blocks.c, misc/nand-mlc-write-blocks.c,
misc/nand-mlc.c: Changed bad block handling. Support for non-aligned
data. Documentation.
* misc/i2c.c: Bugfix.
* include/.cvsignore: New file.
* include/bspopts.h.in: Removed file.
* misc/nand-mlc-erase-block-safe.c, misc/nand-mlc-write-blocks.c,
include/nand-mlc.h: Fixed write blocks.
Sebastian Huber <sebastian.huber@embedded-brains.de>
* misc/nand-mlc-erase-block-safe.c: New file
* misc/nand-mlc-write-blocks.c: Use lpc32xx_mlc_erase_block_safe_3().
* include/nand-mlc.h: Bad block handling.
* Makefile.am: Fix broken path to cache_.h.
* Makefile.am: Fix broken path to clockdrv_shell.h.
* Makefile.am, preinstall.am: Cache manager changes.
* Makefile.am, preinstall.am: Install new header files.
* include/bsp.h, include/emc.h, include/lpc32xx.h, misc/emc.c: Update
for API changes.
* configure.ac, include/bspopts.h.in: New BSP option
LPC32XX_SCRATCH_AREA_SIZE. Disable BSP option
LPC32XX_DISABLE_READ_ONLY_PROTECTION for all BSPs.
* include/boot.h: Removed application specific defines.
* include/nand-mlc.h, misc/nand-mlc.c: Changed configuration layout.
* include/mmu.h, misc/mmu.c: Documentation. Bugfix.
* include/bsp.h, startup/bspstarthooks.c, misc/restart.c,
startup/linkcmds.lpc32xx_mzx, startup/linkcmds.lpc32xx_mzx_stage_1,
startup/linkcmds.lpc32xx_mzx_stage_2,
startup/linkcmds.lpc32xx_phycore: Support for scratch area. Moved
code into macros for reusability.
* include/bsp.h, lpc32xx/misc/restart.c: Renamed lpc32xx_restart() in
bsp_restart().
* irq/irq.c, misc/restart.c, rtc/rtc-config.c:
* misc/timer.c: Include <rtems/btimer.h>.
* configure.ac, include/bspopts.h.in: More options.
* include/lpc32xx.h: Added watchdog definitions.
* include/mmu.h, misc/mmu.c: Added const qualifier.
* startup/bspreset.c: Use watchdog reset.
* startup/linkcmds.lpc32xx_mzx, startup/linkcmds.lpc32xx_mzx_stage_1,
startup/linkcmds.lpc32xx_phycore: Update due to linker command file
changes.
* include/lpc32xx.h: Added I2S module.
* Makefile.am, bsp_specs, preinstall.am, startup/bspstarthooks.c,
startup/linkcmds.lpc32xx, startup/linkcmds.lpc32xx_mzx,
changes.
* rtc/rtc-config.c: Fixed type.
* include/tm27.h: New file.
* Makefile.am, preinstall.am: Reflect change above.
* include/bsp.h: Fixed lpc32xx_micro_seconds_delay().
* misc/timer.c: Support for timer tests.
* include/emc.h, include/i2c.h, include/lpc32xx.h, include/nand-mlc.h:
Update for <bsp/utility.h> changes.
* misc/mmu.c: New file.
* Makefile.am: Reflect change above.
* configure.ac, include/bspopts.h.in, include/irq.h,
include/lpc32xx.h, include/mmu.h, misc/emc.c, misc/restart.c,
startup/bspstarthooks.c: Changes throughout.
* console/hsu.c: Fixed warnings.
* make/custom/lpc32xx_mzx_boot_int.cfg,
startup/linkcmds.lpc32xx_mzx_boot_int: Removed files.
* include/boot.h, include/emc.h, include/i2c.h, include/nand-mlc.h,
make/custom/lpc32xx_mzx.cfg, make/custom/lpc32xx_mzx_stage_1.cfg,
make/custom/lpc32xx_mzx_stage_2.cfg, misc/boot.c, misc/emc.c,
misc/i2c.c, misc/nand-mlc.c, misc/nand-mlc-read-blocks.c,
misc/nand-mlc-write-blocks.c, misc/restart.c,
startup/linkcmds.lpc32xx_mzx_stage_2: New files.
* configure.ac, Makefile.am, preinstall.am: Reflect changes above.
* include/bsp.h, include/lpc32xx.h, irq/irq.c, rtc/rtc-config.c,
startup/bspstart.c, startup/bspstarthooks.c,
startup/linkcmds.lpc32xx_phycore: Changes throughout.
* configure.ac, include/bspopts.h.in: Added BSP_SMALL_MEMORY option.
* include/lpc32xx.h: Update for utility macro changes.
* configure.ac: Fixed BSP option.
* include/lpc32xx.h, startup/bspstarthooks.c: Added PLL setup.
* startup/bspstarthooks.c: Removed start section attribute defines.
* make/custom/lpc32xx.inc, make/custom/lpc32xx_mzx_boot_int.cfg,
startup/linkcmds.lpc32xx_mzx_boot_int: New files.
* Makefile.am, configure.ac, preinstall.am, include/bsp.h,
include/bspopts.h.in, include/lpc32xx.h, irq/irq.c,
make/custom/lpc32xx_phycore.cfg, startup/bspstart.c,
* make/custom/lpc32xx_phycore.cfg: Workaround for GCC bug 38644.
* include/irq-config.h: Removed file.
* irq/irq.c: Removed superfluous parameter checks.
* csb336/make/custom/csb336.cfg,
csb337/make/custom/csb337.cfg, edb7312/make/custom/edb7312.cfg,
gba/make/custom/gba.cfg, gdbarmsim/make/custom/arm920.cfg,
gp32/make/custom/gp32.cfg, gumstix/make/custom/gumstix.cfg,
lpc32xx/make/custom/lpc32xx_phycore.cfg, nds/make/custom/nds.cfg,
rtl22xx/make/custom/rtl22xx.cfg, smdk2410/make/custom/smdk2410.cfg:
Use VFP floating point model.
* make/custom/lpc32xx_phycore.cfg: Remove -W* flags.
* include/bspopts.h.in: Regenerated.
