* | bsps: Move startup files to bsps | Sebastian Huber | 2018-04-20 | 1 | -64/+0 |
| | | | | | | | | Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | bsps/arm: Add .nocache section | Sebastian Huber | 2014-11-27 | 1 | -0/+2 |
| | | | | | This section can be use to provide a cache coherent memory area via rtems_cache_coherent_add_area(). | ||||
* | bsp/lpc24xx: Use USB RAM for fast data section | Sebastian Huber | 2012-08-20 | 1 | -1/+2 |
* | bsps: Replace NIRVANA region | Sebastian Huber | 2012-06-12 | 1 | -1/+0 |
| | | | | | Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS" region. Move the region definition into the "linkcmds.base" files. | ||||
* | 2010-12-03 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-12-03 | 1 | -2/+4 |
| | | | | | | | | * startup/linkcmds.lpc2362, startup/linkcmds.lpc23xx_tli800, startup/linkcmds.lpc24xx_ea, startup/linkcmds.lpc24xx_ncs_ram, startup/linkcmds.lpc24xx_ncs_rom_ext, startup/linkcmds.lpc24xx_ncs_rom_int: Update due to linker command file changes. | ||||
* | 2010-12-03 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-12-03 | 1 | -1/+1 |
| | | | | | | | | | | | | | * include/lcd.h, misc/lcd.c: New files. * misc/io.c, include/io.h: Documentation, bug fixes, more configurations. * include/lpc24xx.h: Added DAC and I2S. * Makefile.am, bsp_specs, preinstall.am, startup/bspstarthooks.c, startup/linkcmds.lpc2362, startup/linkcmds.lpc23xx_tli800, startup/linkcmds.lpc24xx_ea, startup/linkcmds.lpc24xx_ncs_ram, startup/linkcmds.lpc24xx_ncs_rom_ext, startup/linkcmds.lpc24xx_ncs_rom_int: Update due to linker command file changes. | ||||
* | add support for LPC32xx | Thomas Doerfler | 2009-12-15 | 1 | -1/+1 |
* | renamed lpc24xx BSPs, reorganized linkcmds | Thomas Doerfler | 2009-10-05 | 1 | -0/+60 |
