Update #3285.
* configure.ac: Add RTEMS_BSP_LINKCMDS.
* make/custom/lpc24xx.inc: Remove LDFLAGS.
* make/custom/lpc24xx_ea.cfg: Remove LPC24XX_LINKCMDS.
* make/custom/lpc24xx_ncs_ram.cfg: Remove LPC24XX_LINKCMDS.
* make/custom/lpc24xx_ncs_rom_ext.cfg: Remove LPC24XX_LINKCMDS.
* make/custom/lpc24xx_ncs_rom_int.cfg: Remove LPC24XX_LINKCMDS.
* startup/linkcmds: Remove.
* Makefile.am: Rework linkcmds handling.
* make/custom/lpc24xx.inc: New (Renamed from lpc24xx.cfg).
* make/custom/lpc24xx.cfg: Removed.
* make/custom/lpc24xx_ea.cfg, lpc24xx_ncs_ram.cfg,
make/custom/lpc24xx_ncs_rom_ext.cfg,
Include make/custom/lpc24xx.inc.
* make/custom/lpc24xx.cfg: New (relocated from /make/custom).
* make/custom/lpc24xx_ea.cfg: New (relocated from /make/custom).
* make/custom/lpc24xx_ncs_ram.cfg: New (relocated from /make/custom).
* make/custom/lpc24xx_ncs_rom_ext.cfg: New (relocated from /make/custom).
* make/custom/lpc24xx_ncs_rom_int.cfg: New (relocated from /make/custom).
