path: root/c/src/lib/libbsp/arm/lm3s69xx/preinstall.am (follow)
* Remove make preinstallChris Johns2018-01-251-111/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | A speciality of the RTEMS build system was the make preinstall step. It copied header files from arbitrary locations into the build tree. The header files were included via the -Bsome/build/tree/path GCC command line option. This has at least seven problems: * The make preinstall step itself needs time and disk space. * Errors in header files show up in the build tree copy. This makes it hard for editors to open the right file to fix the error. * There is no clear relationship between source and build tree header files. This makes an audit of the build process difficult. * The visibility of all header files in the build tree makes it difficult to enforce API barriers. For example it is discouraged to use BSP-specifics in the cpukit. * An introduction of a new build system is difficult. * Include paths specified by the -B option are system headers. This may suppress warnings. * The parallel build had sporadic failures on some hosts. This patch removes the make preinstall step. All installed header files are moved to dedicated include directories in the source tree. Let @RTEMS_CPU@ be the target architecture, e.g. arm, powerpc, sparc, etc. Let @RTEMS_BSP_FAMILIY@ be a BSP family base directory, e.g. erc32, imx, qoriq, etc. The new cpukit include directories are: * cpukit/include * cpukit/score/cpu/@RTEMS_CPU@/include * cpukit/libnetworking The new BSP include directories are: * bsps/include * bsps/@RTEMS_CPU@/include * bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILIY@/include There are build tree include directories for generated files. The include directory order favours the most general header file, e.g. it is not possible to override general header files via the include path order. The "bootstrap -p" option was removed. The new "bootstrap -H" option should be used to regenerate the "headers.am" files. Update #3254.
* bsps: Provide <tm27.h> in each BSPSebastian Huber2017-11-271-1/+1
| | | | | | | | | Since the <tm27.h> is highly BSP-dependent and used only by the tm27 test program we must provide this header file for each BSP. Without the preinstall build target each header file must have a unique source header file. Update #3254.
* Remove coverhd.hSebastian Huber2017-11-241-4/+0
| | | | | | | This header file contained timing overhead values which are hard to maintain. Update #3254.
* bsps: Fix build errorSebastian Huber2014-09-181-4/+0
| | | | Fix build error introduced in f535fe5311978af53635c2da8e5cb10ef9d78802.
* Regenerate all preinstall.am files.Joel Sherrill2014-08-281-6/+6
| | | | | Apparently, at some point automake output changed and these were not updated.
* bsp/lm3s69xx: New BSP variantsEugeniy Meshcheryakov2013-04-261-0/+12
| | | | Add support for LM3S3749.
* bsps: Shared ARMv7-M interrupt supportSebastian Huber2012-03-241-0/+4
* bsp/lm3s69xx: FormatSebastian Huber2012-03-241-12/+12
* New (Missed during BSP-import).Ralf Corsepius2011-09-301-0/+103
