Update #3285.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* bsp_specs, start/start.S, startup/linkcmds: Use linker command base
file.
* start/start.S: Verify boot_card() is passed a NULL.
* Makefile.am: Update to current style.
* bsp_specs: Fix warning for _start.
* start/start.S: Proper attribution for origin.
* startup/bspstart.c: Add Skyeye bsp_reset() on Skyeye.
* include/.cvsignore: New file.
* include/bspopts.h.in: Removed.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, console/uarts.c, include/bsp.h, include/bspopts.h.in,
include/tm27.h, start/start.S, startup/bspstart.c, startup/linkcmds,
startup/memmap.c: New files.
