Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS"
region. Move the region definition into the "linkcmds.base" files.
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
XXX
for details.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
PR 1917/bsps
* Makefile.am, console/uart.c: Modifications to add dynamic tables for
libchip serial drivers.
* startup/bspreset.c, startup/bspstart.c:
* gba/clock/clockdrv.c, gba/console/conio.c, gba/console/console.c,
gba/console/defaultfont.h, gba/include/arm_mode_bits.h,
gba/include/asm_macros.h, gba/include/bsp.h, gba/include/conio.h,
gba/include/gba.h, gba/include/gba_registers.h, gba/irq/irq.c,
gba/irq/irq.h, gba/startup/bspstart.c, gba/timer/timer.c,
gp32/include/bsp.h, gp32/startup/bspreset.c, gp32/startup/bspstart.c,
nds/tools/runtest, shared/comm/uart.c, shared/comm/uart.h,
smdk2410/include/bsp.h: Fix typo where license said
found in found in.
* start/start.S, startup/linkcmds: Use linker command base file.
* Makefile.am, preinstall.am: Added generic interrupt support modules.
* include/bsp.h: Define BSP_FEATURE_IRQ_EXTENSION.
* startup/bspstart.c: Interrupt support changes.
* csb336/make/custom/csb336.cfg,
csb337/make/custom/csb337.cfg, edb7312/make/custom/edb7312.cfg,
gba/make/custom/gba.cfg, gdbarmsim/make/custom/arm920.cfg,
gp32/make/custom/gp32.cfg, gumstix/make/custom/gumstix.cfg,
lpc32xx/make/custom/lpc32xx_phycore.cfg, nds/make/custom/nds.cfg,
rtl22xx/make/custom/rtl22xx.cfg, smdk2410/make/custom/smdk2410.cfg:
Use VFP floating point model.
* console/uart.c: Fix warnings.
* start/start.S: Verify boot_card() is passed a NULL.
* smc/smc.c: Replace EBADRQC with EINVAL.
* make/custom/gp32.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/gp32.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* include/bsp.h: Eliminate BSPs defining NUMBER_OF_TERMIOS_PORTS.
Should be automatically handled by confdefs.h or the application.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* start/start.S: Update for boot_card command line change.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Remove noinst_PROGRAMS (Unused).
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* Makefile.am, configure.ac, console/uart.c, startup/bspstart.c: Use
standardized bsp_cleanup() which can optionally print a message, poll
for user to press key, and call bsp_reset(). Using this eliminates
the various bsp_cleanup() implementations which had their own
implementation and variety of string constants.
* startup/bspreset.c: New file.
* startup/bspclean.c: Removed.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* startup/bspstart.c: Remove unnecessary includes of
rtems/libcsupport.h and rtems/libio.h.
* Makefile.am, configure.ac, startup/bspstart.c: Split out
bsp_get_work_area() into its own file and user BSP Framework to
perform more initialization. Use same shared implementation as
edb7312 and csb336.
* Makefile.am: No BSP should use exit.c as a file name. exit() is POSIX
routine.
* startup/bspclean.c: New file.
* startup/exit.c: Removed.
* smc/smc.c, startup/exit.c: Add missing prototypes.
* smc/smc.c: Fix the fix. The field is bufnum.
* smc/smc.c: Fix warning.
* smc/smc.c: Updated to the libblock changes.
